AH FabricationsEM Tuning
    Oct 2011
    Newcastle Upon Tyne
    57
    S-tronic reset/flash costs?
    Hi all
    I was hoping somebody on here would be able to give me an idea of how much it would cost to have my s-tronic gearbox reset by audi?
    I've been over to my dealer this morning and i have a slight problem with the gearbox. It is juddering into 2nd gear.
    The service mechanic seems to think that if i had the gearbox reset it would resolve the problem.
    I was just wondering whether people think this could solve the problem and a rough idea on cost.
    Thanks Jonny
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    S-tronic reset has been known to cure rough gear changes and general unsmooth operation. Not sure how much Audi will charge but it wouldn't be cheap knowing their hourly charge.
    If I were you I'd spend the money on VCDS from member NHN and do the reset yourself using this guide ----------> 6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki
    You'll then have a diagnostic tool for all future faults/coding/etc.
    Aug 2003
    292
    I'd like to try this to get smoother 1st gear changes, I have VCDS but am nervous to try it.
    Is there any risk involved?
    Mar 2011
    Cleveland
    993
    Quote Originally Posted by paultaylor View Post
    If you mean the bit of a jerk you get if you go quickly from brake to throttle, then that's normal. It takes a second or so for the electronics to do there job.
    I'm pretty sure you can't programme it out.
    I get round it by using the handbrake.....
    Aug 2003
    292
    Quote Originally Posted by fangio View Post
    I've been told a new mechatronics unit is the only surefire fix.
  1. need a wireless flash which one
    By reece-page in forum Photography & The Digital Darkroom
    Last Post: 15th February 2012, 19:45
  2. alarm flash flash
    By steve bain in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2011, 13:51
  3. Service interval reset after ECU code reset
    By mikedavey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2010, 20:08
  4. No Flash
    By northernlights in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2009, 21:07
  5. ecu flash
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2007, 15:29
