JMB RetrofitsBadger5
Results 1 to 30 of 30
    marwayg's Avatar
    Sep 2011
    217
    LPG Conversion - 3.2 v6
    I am interested in doing a LPG conversion on my 3.2 V6...
    has anybody done it?
    Few questions -
    - Cost?
    - Results?
    - Power changes?
    - all information about the conversion
    Cheers all !!
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by marwayg View Post
    Few questions -
    - Cost?
    - Results?
    - Power changes?
    Cheers all !!
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    I doubt it would take you long to get your money back on the conversion, but why buy a 3.2 and worry about fuel consumption?
    A3 3.2 Quattro Sport
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by willowsdad View Post
    Exactly !!!
    marwayg's Avatar
    Sep 2011
    217
    Well, im selling the car at the moment. And i am not getting much response. So i just thought that if i kept it, id just LPG conversion it to save myself more in the long run.
    If only i could sell it... i would... but i am not getting much response (if any) www.pistonheads.com/sales/3737206.htm
    Any ideas how much it will cost to LPG it? and whether there will be power losses? or specific people i can talk to who have hands on experience in this field?
    audigex's Avatar
    Jul 2011
    555
    You can essentially double your miles per £, as you do about the same mileage per gallon of LPG, but for half the money. Disadvantages are that the tank takes more space.
    You'd normally expect a loss of 10-15% of power converting to LPG, although some report up to 20% and others say nothing - from what I've seen, smaller engines lose more than larger, so it might be non-linear or a more fixed loss rather than an absolute percentage.
    Cost can be under a grand, although whether the V6 adds anything to that I have no idea. I'd budget £1500, which seems a lot to recoup.
    There are sequential systems too, no idea what the difference is technically speaking, but apparently it avoids the loss in power although is more expensive to install.
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    A friend of mine has an LPG 330 Convertible he says he can't notice any difference in power the only thing he's noticed is more cash in his back pocket. He reckon's it costs him about half of what it would using petrol although you do get slightly worse MPG using LPG.
    If you do the mileage it's worth it, however take note that LPG takes a whilst to kick in and doesn't work whilst the engine is cold, so if your just doing short journeys it won't be worth it.
    Cost wise although a while ago now it cost about £1500+ but he got some prinz system or something like that.
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    brasiliangringo's Avatar
    Mar 2010
    544
    Its a no brainier if you do average miles + and plan on keeping the car say 2-3 years, using 1500 is a good basis for your outlay then just do the figures. I amazed more people haven't taken to it over here in the UK.. Its far more wide spread on the continent.
    audigex's Avatar
    Jul 2011
    555
    It's also far cheaper on the continent - 0% duty in most of Europe.
    Pics
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    I've introduced gas fleets for 3 different companies now from Small vans up to Artics.
    You get what you pay for, make sure you use an LPGA company and push for a 2 year warranty. Multipoint systems are now the norm and Prins is a good manufacturer, as is Romano and BRC but I'd budget for up to £2k on your 3.2 for a good kit installed & certified and a good remap.
    You shouldnt notice a power loss until you put passengers in the car as your engine torque will be slightly lower on the gas, you may notice some pinking when there's weight in the car so you may have to adjust your driving style and hold the revs higher than previously before you change up. Also make sure the car is properly remapped for the gas conversion and have new plugs & filter changed prior as the engine will run lean on gas....
    Mar 2011
    LONDON
    47
    Old systems can have leaks so its worth factoring a yearly check or a decent warranty as previously mentioned, you may need to inform insurance company but you get to keep a nice car and diesel noise is not for everyone. I worked for BOC for years who supply gas and the boys were doing diy kits themselves over 30 years ago but I wouldnt reccomend that! And dont forget you will have a bit of an ugly lpg cap on the side of your pride and joy.
    Apr 2012
    NL
    77
    I investigated this a couple of weeks ago because there was a nice 3.2 on sale, which was on LPG. Spent quite some time on (German) forums. Although some say it can be done, most say it cannot be done because of the way FSI engines work (the type of fuel injection wouldn't allow for it, which causes the valves to heat up, which will wreck things in the long run).
    My conclusion after the research was: stay clear of 3.2's on LPG.
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    Quote Originally Posted by andy1acars View Post
    You have to have the systems re certified each year and you also have to inform your insurance company.
    They systems are very safe, theres a minimum of 3 safety valves inline from the injection system back to stop you blowing up and the tanks are usually 10mm thick or more.
    Don't be put off by the gas cap, you can have it fitted somewhere subtle, on the bottom face of a bumper or just in side the boot lid as long as you can fill up without gas getting into the cabin
    marwayg's Avatar
    Sep 2011
    217
    Yeah im taking this into consideration.
    I forgot to mention that my car is DSG automatic paddle shift. Would that have an effect on the LPG conversion?
    And unless anybody knows of people interested in a purchase of my 3.2, i am going to stick to LPG converting it.
    thanks for the replies guys!
    Mar 2010
    544
    Quote Originally Posted by audigex View Post
    That is not true, most countries have excise duty etc..
    Europe's Energy Portal Fuel Prices, Rates for Power & Natural Gas
    Mar 2010
    544
    You can get it put in where you want but for it to be hidden just costs a little more. Ie hidden behind filler cap/flap.
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    Putting LPG on a 3.2 V6 is like going to a brothel and asking for a kiss..
    2008 A3 1.8TFSI 3 Door S Line - Lava Grey - Bose - Bluetooth - S Line Full Black Leather - Aux - Comfort Pack - Coming Home Lights - Storage Pack - Cruise Control - Ambient Interior Light - Footwell Lights - Audi IPhone 4 Cradle - Leather Armrest - BE Rear - MY09 Rear Lights - S3 Pedals - S3 Vents - BBS RS866 - Bi Xenons - Bluefin Stage 1 - K&N 57S Intake - Rev D Valve - Powerflex Dogbone Insert & Gear Box Mount
    Mar 2010
    544
    Quote Originally Posted by Farhan View Post
    Why, what makes you say that ?
    marwayg's Avatar
    Sep 2011
    217
    LOLLL i like the comparison!!
    but seriously guys, in hindsight, yes or no? Financially speaking ... is it worth it?
    Mar 2010
    544
    Mate, do the figures, it clearly makes sense, but i cannot comment on the particular application to your said engine although some suggest it is like asking for a kiss in a brothel etc etc, although i dont believe that is a good comparison and believe it is quite safe.
    Mar 2010
    544
    I know people running it on some cars like an xjr, v8 Range, B5 s4 and all are very happy..
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    You can also apply to dvla to have the car re certified for emissions and registered as an LPG vehilce giving a saving when you tax the car. You can also register with Powershift or Transport for London for £10 and you will then be exempt for the London congestion charge which is £10 per day.
    marwayg's Avatar
    Sep 2011
    217
    right-o. going to start looking at some quotations etc. Thanks for your help guys!!
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    Honestly i said the comment as a bit of banter, dont take it personally.
    If you are struggling to sell the car for the money you want for it, re consider it.
    The cost of LPG is around circa 800-900+, Would you actually make a saving in petrol prices for maybe a year or two before you decide to sell it again. It may be worth accepting around £1000 less and getting yourself something newer, different and a turbo engine to satisfy your needs.
    I had a friend who did an LPG conversion on his BMW, i was like WOW this is epic very cheap to run. He got bored of the car after a couple of months and sold up. Just made me think what was the point of converting it? Do you do enough miles to warrant the LPG and will you have the car long enough?
    sinic's Avatar
    Audi WAudi
    Jan 2011
    256
    +1
    Make sure you're going to keep it a while after converting it as it wont add any value to the car and may make it harder to sell, if you're likely to sell it within a couple of years then just sell up now, get what you want and if its going to be a petrol car then maybe get it converted as soon as you get it.
    If you want the car long term...over 2 years or more and do reasonable miles the go for it.
    May 2010
    34
    Quote Originally Posted by brasiliangringo View Post
    wont belong before the cylinder liners drop on the range rover then,
    if you buy a car with a big engine in it expect big fuel bills,if you cant afford to run it as intended by the manufacturer sell and buy something smaller.personaly i would not touch lpg it just causes more problems,go to any forum that caters for large engined cars and theres always someone with aproblem with lpg
  28. #27
    Mar 2010
    544
    Quote Originally Posted by adesb5 View Post
    Be interesting if you could expand on that as factual information like this is useful to know ?
  29. #28
    Farhan's Avatar
    Feb 2011
    West London
    1,228
    I have no experience with this myself but the source below seems like a very interesting read.
    LPG Problems
  30. #29
    Mar 2010
    544
    Interesting post Farhan but slightly confusing as they start off saying its not worth it (they sell and install LPG) then go on to sell a sequential system at the bottom of the page, saying how incredible it is.. Anyway the point would seem to suggest some modern cars are not suited due to valve seat recession due to modern manufacturing (post 2006 according to them) cost cutting and making internal parts on the cheap !!
  31. #30
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    637
    As I understand it, the problem with the newer FSI engines is that the petrol acts as a cooling element for the injectors and LPG does not, so with standard LPG you'd be changing your injectors every few months. Prins have recently brought out a new LPG system for newer FSIs, up to 3.2 incidentally, which I think runs 75% LPG/25% petrol. It's called VSI DI. I expect other specialists will be following suits with their own systems too.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
  1. lpg conversion
    By MoAudi1.8T in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2009, 15:35
  2. 1.8T conversion to LPG
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2008, 19:46
  3. LPG Conversion
    By baynesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th April 2008, 15:55
  4. LPG Conversion (S4 b5)
    By tom-m in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2007, 18:57
  5. LPG conversion
    By gidimille in forum General Technical / How To
    Last Post: 5th January 2006, 19:38
