Chris NottMonster Motorsport
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By MTRL
Thread: Need advice on new key
    a3sline_nottingham's Avatar
    Mar 2012
    64
    Ok so I bought my car but only got 1 key
    There are loads on eBay and the part numbers match mine, including the number behind the part where the key flips out
    If I buy one and a blank HAA blade is there anywhere in Nottingham or close to east midlands who will cut the blade and reprogram the key to my car
    Does anyone have the software and k now how to do it on he forum
    Thanks in advance
    I really don't want to spend the £190 I was quoted from Audi for a new one.
    SiT
    Apr 2008
    Tyne & Wear
    98
    I would honestly go to Audi and get one done properly even if for peace of mind. The fact that you’re contemplating £190 for a premium car surely says it’s worth going to the dealer for..?
    rOb_A's Avatar
    May 2010
    cheshire
    1,485
    yep £190 for a key, is steep! can't you programme the key using another key or your car? sure i have read something on these lines
    brough74's Avatar
    Oct 2010
    423
    Ive tried it and my recommendation is go to audi and order one as its much leass hassle and it will work.
    S3 gone but not forgotten, now on a Golf R
    Fossie
    Rhubarb Triangle
    3,969
    The only way to get a key that is capable of starting the car is to obtain the 'secret' code for the immobiliser chip. This is held at Audi Germany and is only available to dealers who will require proof of ownership before they get it.
    Some specialist VAG independents may have software capable of extracting the code from the existing key but they are few and far between.
    Getting a spare key to unlock the vehicle both with the key and by using the remote is quite easy by buying the right fob off ebay and getting a blank blade cut and then using VCDS to programme the remote bit. This, however, will not enable you to start the car because the immobiliser chip and remote control modules are completely separate inside the key fob.
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Key insurance, its a must for audi owners.
    OVRA3 likes this.
    ....................I'll make a build thread one day.
    27,114
    Goto audi, been down this road many times with members, using another slightly cheaper source can leave you prone to theft as keys can be copied or extra's made whilst being coded, why risk your car for being tight
    audigex's Avatar
    Jul 2011
    556
    Audi can remove any keys apart from the one you have with you, too - it's not just about getting a new key, it's about making sure that nobody can use the keys you don't have.
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by audigex View Post
    You can do that with VCDS !
  1. Advice please, Possible key or immobiliser problem?
    By Beardo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 19:25
  2. Replies: 3
    Last Post: 17th January 2010, 18:49
  3. Key fob/flip key
    By RadCap in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2009, 14:37
  4. vallet key? my key doesnt open th eboot lock?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th July 2004, 15:16
  5. Help! Advice on Spare Key please!
    By AndyMcUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2003, 20:33
