Chris NottMonster Motorsport
Results 1 to 7 of 7
    Dec 2011
    Computer shows a warning about Brakes
    My computer shows a warning about brakes and the red light comes on in the speedo. I thought this might mean brake fluid low but its at the correct level, pads are almost new as well. Does anyone have any other ideas what this could mean?
    a3_sline_tdi's Avatar
    Aug 2009
    894
    Just top it up a little and should go off this happened to my mate te other week and light went off
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    26,721
    Pic?
    Jul 2010
    561
    The pad wire is easily damaged and can give a pad low warning when they're fine.
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    872
    When I first bought my car, I got the warning "Left rear brake light" I thought it meant the brake pads were light, almost worn out lol. It was actually the brake light that was out. Embarrassed myself at the garage.
    Dec 2011
    Thanks for the suggestions. I topped up and all was fine for about 30 miles. After which it returned along with dreaded Yellow traction control light, which I understand means the ABS Pump has failed :-(
    26,721
    Get it scanned as could be a number of issues that we're speculating about, also if you ask for help & in return people ask you for more info, unless you provide that info, namely pics as some people get the warnings wrong, then how are the said people offering help supposed to do so, so show us the icons that are showing in your dis or lamps.
  1. RS4 tyre pressure warning on dashboard computer
    By mjmfj in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 14th August 2011, 22:17
  2. Warning (maybe brakes?)
    By kachnak in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2011, 14:17
  3. Amber warning after fitting S4 brakes
    By TheONEin10 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th June 2010, 21:17
  4. DIS Warning on startup! BRAKES
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th February 2007, 10:59
