AH FabricationsChris Nott
Results 1 to 14 of 14
    Lensey's Avatar
    Oct 2011
    Essex
    29
    Lowered the car but have a problem with lights
    Hi Guys, I wonder if anyone can help me with this problem? I had the S3 lowered 25mm using H&R springs on Friday, just been out in the dark and the lights are really low! I stopped the car and restarted it and the beam went up and came down as usual but I presume they are coming down too much. Could the problem have something to do with the lowered springs I've just had put on?
    2010 S3 QUATTRO
    Leather
    Sat nav
    audigex's Avatar
    Jul 2011
    555
    The lights are auto-levelling - they counteract hills or the suspension rake but they only work on the angle from the horizontal... they have no way of knowing how high they are, so they can't compensate for this... nor should they (much), otherwise your lights will be pointing up into people's faces.
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    ok so yes the lights are auto levelling as you said that they go up and then back down when you switch them on.... that just the check it does when it first turns on.
    as you have lowered the car the lights are pointing lower. what you need to do it use a screw driver (cant remember but i think its a philips or torx) and use it on the 2 white screws on the top of the headlight to manually raise the lights upwards.
    now i would advise that you do this in a MOT testing station as they can then tell you the correct height the headlight needs to shine so that you are not blinding oncomming drivers.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    Lensey's Avatar
    Oct 2011
    Essex
    29
    Thanks guys much appreciated
    2010 S3 QUATTRO
    Leather
    Sat nav
    Jun 2011
    52
    Edit - beat me to it
    26,776
    NO, dont just raise them with screw turns, you need to get someone with vcds or dealer vas & turn on the mot mode 1st, they preset themselves to a position, then you adjust with the screws with the proper lense, then disable mot mode, do it properly please or you'll get irrate people flashing/waving at you for the wrong beam pattern.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    Ahh my bad, I forgot about the mot mode
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    26,776
    Dont worry, memory gets worse with age, luckily we have computers lmfao.
    Lensey's Avatar
    Oct 2011
    Essex
    29
    So if I'm understanding this right, you turn the MOT mode on, set the lights up then unclick MOT mode, that then sets the lights to that setting?
    2010 S3 QUATTRO
    Leather
    Sat nav
    26,776
    Thats pretty much it, you have to be on an mot bay ideally, as these have to be flat, but of course bit more clicking & selection of modes within vcds.
    Lensey's Avatar
    Oct 2011
    Essex
    29
    So I could purchase the VCDS and go to the MOT place around the corner and get them to set the lights up? How much is the VCDS?
    2010 S3 QUATTRO
    Leather
    Sat nav
    26,776
    Yes & I have a Group Buy going atm, check my link in sig, its £230.
    Also, check you havnt had the levelling sensor arms snapped by the suspension installer, cant miss them under the car, left front if you turn wheel full lock left can be seen behind the suspension low down & under car rear left also attached to the lower arm.
    Lensey's Avatar
    Oct 2011
    Essex
    29
    The group buy closes on the 5th April, when do you reckon delivery would be?
    2010 S3 QUATTRO
    Leather
    Sat nav
    26,776
    Well you can always pay the £249.50 now, which is still cheapest in UK it should be sent tomorrow & arrive following day, but as we have a bank holiday looming, the cables wont be with GB buyers until beginning of next week.
  1. problem with my s3 after i lowered it?
    By mr-scriv in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2008, 17:00
  2. Lowered car + folded down car park barrier....
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2008, 16:27
  3. How do I know if my car has been lowered???
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2007, 15:24
  4. Head lights INCORRECT adjustment LOWERED S3
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2006, 18:54
  5. Has my car been lowered?
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2004, 23:05
