Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Jan 2011
    119
    a3 2.0 tdi BKD 8P fault codes after remap!!! worried!!!
    Hi Guys,
    Had my audi a3 2.0tdi BKD 8p remapped yesterday and the car has been going great, more power, more response really happy with it. However i just wanted to hook the car up today to check for any faults just in case and i have found a few! im really worried that its related to the remap but im not sure. Here are the faults that where logged:
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705
    Revision: 12345678 Serial number: AUX7Z0CDFN20D6
    Coding: 0000072
    Shop #: WSC 01286 386 08256
    VCID: 27567E6AEF85
    1 Fault Found:
    16725 - Camshaft Position Sensor (G40): Implausible Signal
    P0341 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 336 /min
    Torque: 88.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 10.34 V
    Bin. Bits: 11000100
    Idle Stabilization: 0.0°KW
    (no units): 3.0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    VCID: 3A70B71E0C37
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000388879
    Coding: 03884F00A2141000000000000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7EB21A030D
    Part No: 8P2 955 119 C
    Component: Wischer WWS Audi350 0180
    Coding: 16711696
    Shop #: WSC 00000
    6 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01320 - Control Module for Climatronic (J255)
    00483 - Control Module for Auxiliary Air Heater
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    00466 - Control Module for Steering Column Electronics (J527)
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    VCID: 2E588B4EC07F
    2 Faults Found:
    02441 - Yellow Malfunction Lamp in Instrument Cluster
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Mileage: 7440 km
    Temperature: 27.0°C
    Voltage: 12.10 V
    Voltage: 11.90 V
    Freeze Frame:
    Mileage: 7480 km
    Temperature: 31.0°C
    Voltage: 12.30 V
    Voltage: 12.20 V
    I have cleared all the faults and they havent come back but i havent taken it for a drive yet since i cleared them.
    Should i be really worried? Are they all serious faults? Do you think they are related to the remap?
    I would really appreciate some advice on this. Any help at all would be great!!
    Chris
    Jan 2012
    464
    Depends who remapped it - some maps produce spurious errors whilst the map is loading, so if they don't come back you're OK.
    Do you recall if the tuner cleared the fault codes?
    Jan 2011
    119
    Hi Mate,
    I have cleared the errors and have taken the car out again and give it a good thrashing for about 20 miles, brought the car back and done a scan and it hasnt thrown up any errors!
    Do you think this means that its ok now? Why would it produce spurious errors? does this happen if the map isnt very good? The tuner never cleared the fault codes. Its a local tuner that i used but he is well known and came highly recomended by alot of people. I live in the Scottish Highlands so its very difficult getting the car to somebody to do a remap. The guy that did it was using software called Alien tech with a tuning box that read Kess v2 Master Version. He downloaded my original and then customised it etc and then uploaded it on to my ecu. Does this sound about right? i dont know much about remapping tbh. Does that software and hardware sound familiar? Have you heard of it before?
    Chris
    Jan 2012
    464
    Yeah, I don't think you have anything to worry about. I've had a number of different maps on my cars and the range of fault codes is different for each one. The tuner should normally clear them before giving you the car back but it's no big deal. There should be timestamps on the error codes that should link back to when you had it mapped, although some codes could've been there beforehand and you just never knew about them?
    Jan 2011
    119
    ah right, How can i view the time stamps? I was actually looking to see when the faults where actually logged but couldnt find a time anywere, is there a way to find out? It was proabably 2 weeks before i had the remap that i did the last scan so they could have been there before i suppose but i just thought it was a little coinsidental! Have yo heard of that tuning software and hardware before?
    Chris
    27,031
    Chris, dont worry yourself, just scan in a weeks time, then a month, if nothing comes back then should be fine.
    Strange as all my maps on cars with same guy Simon@amd surrey, has never produced even a whiff of module errors, but with modern ars its possible, I know when I get cars mileage corrected to the right amount for DIS upgrades, it creates errors as it cycles power etc to cluster etc while ignition is on, but clear them down & never come back.
    Jan 2011
    119
    Cheers Nige, a little reassurance is all i needed. I have done another 40 miles today and have just done another scan, not logged any faults so hopefully its ok. Have you heard of this type of map before Nige? the Alientech kess v2 master version hardware etc? or ecm for producing maps. Got to admit, im an IT officer but when it comes down to remapping im not sure how it all works!!
    27,031
    Alientech srl - Electronic Performance
    They've been around for a while iirc, just checked they're in Italy Turin area, 5 hours from our italian home lol.
  1. remap causing fault codes?
    By burns277 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2011, 19:25
  2. A3 2.0tdi BKD Fault codes :(
    By j50sho in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2010, 15:06
  3. FAULT CODE......A3 TDI 2.0 BKD
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th January 2010, 19:18
  4. Amd remap fault codes help
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2010, 22:21
  5. Fault codes since remap
    By Broken Byzan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 02:37
