Volks AutosChris Nott
    Mar 2012
    21
    DMF dual mass flywheel on BKD dsg
    My flywheels on its way out and my car sounds like it belongs on a farm yard!
    I have found a garage locally that will fit one for pictures of the queens face (cash in hand) as long as I supply the parts.
    What parts do i need? just the DMF or is there any seals or other bits and bobs that are changed at the same time.
    My gearbox oil was changed 5K ago and the clutch is fine.
    Wicked awesome.
    tdi-man's Avatar
    Jul 2009
    1,612
    i would change clutch with flywheel go for a saches one.
    also gearbox oil seal .
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Mar 2012
    21
    Its a DSG so wasn't going to touch the clutch as it seems fine and is only on 75K.
    So you recon a gearbox oil seal, is this applicable to the DSG?
  1. Help - Another Dual mass flywheel on its way out
    By amgad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2012, 00:11
  2. Dual mass flywheel
    By cee-gee in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th May 2011, 19:03
  3. Dual Mass Flywheel - Does my A3 have one?
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 16:02
  4. Do DSG-equipped cars use dual mass flywheel?
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 21:07
  5. Dual Mass Flywheel
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 15:38
