Those of you with LED DRL's...
lil_coz
Just want to check on something... I've noticed that the LED's get a lot dimmer when I'm using indicators on my car. So if I'm indicating left, the left LED's will get dimmer by a noticeable amount! The ones on the right stay as bright as normal. Is mine alone at doing this or is it normal?
Cheers,
It's normal, it's a safety feature to make the indicator more visible when in use....
They are meant to do that so the indicator can be seen better - my non LED DRLs do the same.
you can turn off that with vcds.
That's fair enough. Only noticed it yesterday so thought I'd check in with you knowledgable chaps. :icon_thumright:
Cheers guys!
You will notice they get a lot dimmer as side lights with headlights as a posed to driving lights too
