Results 1 to 12 of 12
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    No numberplate illumination
    Dont know if this is related to what Ive ben doing with the CH/LH mod but here goes.
    L/H numberplate LED stopped working and as the screw had rounded off went to the Audi garage to buy 2 more holders so I could replace both together. After cutting it off the car LED bulb popped back the holder and fitted to the car.......no illumination. I then changed the R/H holder with the same LED bulb and now that doesnt work either. Ive tried turning round the bulb for polarity reasons and swapped sides but both sides no longer work.......I had a look at the side fusebox but nothing blown. Kinda stumped now. Anyone had this before.
    Could it be that the 2 LED bulbs have gone????
    Now going to rip my garage apart to find the bag of normal bulbs that I took out when I did the LED conversion.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    warren_S5's Avatar
    Oct 2007
    7,166
    Fuses checked......?
    Audi S5 3.0V6T Coupe Black Edition
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,406
    All fuses checked OK. Figured out what it is though. Managed to find the old bulbs and fitted them. Turns out that both LED bulbs had blown as there were signs of scorching around the ends of both LED's and they were exceptionally hot. Dunno what could of caused this as they have been fine up to now. Looks like I will have to get another pair from Trups. Its never ending. Car is running like a dream though so I aint complaining.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    Hey Bud, have you tried popping the standard bulbs back in to see if they still work. Reason I ask is that I've heard that on 8P2's that once the numberplate light error has come up - ie when the bulb stops working - you need to have the fault cleared via VCDS. It might be that there is nothing wrong with the other LED that was working before, the Canbus system may have just completely shut the wiring connection down until the fault is cleared. xx
    See this thread
    Bloody LED number plate bulbs won't work - doing my nut!
    EDIT Glad you've worked out what it is, ..strange both bulbs have gone though.
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,406
    Hi Paullie
    Yeah I cancelled out the fault and did another scan and it was still the same. Both are working now but with normal bulbs so will have to get Trups to send me another 2. I knew LED's got hot but not that hot to scorch the end of the bulb.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    Yeah Bud, Trups will sort you out with some more no probs, for sure xx
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    LED stands for light emmiting diode a diode is essentially a non return valve for electical power
    This is why they only work if installed with the correct polarity
    They emit light when voltage is applied with the correct polarity
    If measured with an ohmeter from + to - there will be 0 ohms but if measured between - to + it will be infinte ohms
    The original 501 lamps will be so many ohms (im not sure exactly) and the more.ohms applied to the 12 volts on your car
    Decreases the current (amps) your car detects
    When the curent detected is diffenent to what the original bulb is the car knocks the power off to that circuit
    You will need the can bus ones whuch have a resistor in to make the current the same as the standard bulb
    I tried these once and my car detected a fault still but.if your turn the car off then on again it should try the circuit again
    I bought the cheap ones off ebay so.no wonder they didnt work
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,406
    Eh thanks for that Jack_tdi......but I think you've got the wrong end of the stick there but thank you anyway for informing me and everyone else on how LED's work.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    xx
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    I only explained that as when my car detected a fault it turned the power off to that circuit
    I was only trying to help........... next time.i wont bother
    Feb 2008
    Europe
    231
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,406
    Quote Originally Posted by Jack_tdi View Post
    Was only having a laugh with you Jack_TDI. This forum isnt all straight laced......we can have a joke sometimes. Everyones input is greatly appreciated.
  1. ** S3 Numberplate **
    By miss_lucy in forum For Sale/Wanted - Audi Parts
    Last Post: 7th August 2011, 17:40
  2. Numberplate Lights
    By Phantom_A4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th May 2011, 19:13
  3. bodged on numberplate
    By tyson in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2010, 12:00
  4. Numberplate...
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2009, 20:36
  5. Numberplate suggestions please
    By pea. in forum General Chat
    Last Post: 2nd January 2007, 20:18
