Sky InsuranceJMB Retrofits
Results 1 to 13 of 13
    Mar 2012
    Carlisle
    6
    Add Poppy12 on Facebook Visit Poppy12's Instagram Channel
    Lightbulb Front wiper motor? HELP
    Hey, Not sure if im even posting this in the right area or correct forum but.. What it is, is... My wiper motor (front) has packed in, my friends have tried the fuses for me its not that its totally dead. Will a motor off a 58 Golf fit? my audi is a3 08 plate, and how easy are they to fit.. ive heard that it requires a bit that could potentially crack the window when taking the black plastic off? Is this the case?
    Any help would be greatly appreciated
    Poppy x
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Moved from A3 8L to A3 8P
    <tuffty/>
    HIGGINS's Avatar
    Mar 2010
    523
    Quote Originally Posted by Poppy12 View Post
    Poppy x
    Im not 100% if the golf motor will fit. The scuttle tray is pretty tricky to remove if your doing it for the first time. It has a lip going down below the glass and you have to keep tugging it at to loosen it and you can eventually pull it away. I cant imagine damaging the window if your using your hands.
    Selling MY11 rear lights, message me for a price
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Poppy x
    Have you fitted a aftermaket HID kit to your A3?
    Ron
    Audi A3 8P2 2.0Tfsi S-Line Special Edition Bluefin
    3dr Mauritius Blue || Full Leather|| BOSE || MFSW || Auto Lights/Wipers || Auto Dim Rearview Mirror || Heated Mirrors
    Mods: S3 Aluminium Pedals || S3 Vents || 2010 RNSE || OEM Bluetooth || Dension Gateway 100 || MY09 Rear Lights || Single Xenon Headlights
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    check part numbers with a local dealer or parts center
    Mar 2012
    Carlisle
    6
    Not sure on HID kit but... Someone did but different bulbs in... Not sure what kind maybe xenon and it is since then, there not in my car now as they didn't work properly
    27,111
    You would need your current part number to scout for another of the same or a supercession unit, removal/fitting is a little tricky, but not exactly rocket science, plenum chamber cover needs slightly flexing to remove, but once thats of, should be obvious from then on.
    BlueSpark's Avatar
    Aug 2010
    South London
    386
    Well if was a HID kit previously fitted then that is more than likely what caused ur wiper motor to blow. Hope you get the wiper motor fixed but note not to fitted HID kits in future and go down OEM xenon root if you what xenons.
    Ron
    Aug 2010
    1,540
    whats the link between hids and failed wiper motors?
    Fossie
    Rhubarb Triangle
    3,969
    Do a search mate : Hid, Wiper motor problem?
    27,111
    The common point between the halogens & the wiper motor is the grounding point 366, I suspect the lin bus is damaged within the wiper motor & thus ceases to function as xenons require a fair whack to startup, feedback down the common wire maybe an issue, who knows without testing with the relevant diagnostic tools.
    Aug 2010
    1,540
    had a mk5 golf in last week with a hid kit fitted. no wiper problems, but.....
    with the dipped beam on if you flick high beam on, one or the other hids flickers for a second then goes off.
    also even if you dont touch the high beam after about 15/20 mins of dipped beam being on the same happens, one of them flickers and goes off.
    diddnt really get anywhere with it as i was busy doing other things. any ideas?
    27,111
    Probably shares the same ground point again & its getting feedback/interference, only way to realistically stop any issues is to run seperate wires to the kits from the battery & chassis ground point, then relay it, but you'd have to do some measurements of the resistance with halogens & recreate this with resistaors or the like, so the relayed circuit shows the onboard diag that the bulb isnt blown or you'd have dash warnings I suspect.
  1. Front wiper motor part number?
    By spankius in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2012, 20:22
  2. Weak Front Wiper Motor
    By Lowride in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th March 2012, 08:58
  3. Front wiper motor replace on A4 B6
    By Phil MC in forum General Technical / How To
    Last Post: 12th April 2011, 11:44
  4. Front Window Wiper Motor Recall ?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2010, 18:39
  5. Front wiper motor price?
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2010, 20:18
