Volks AutosEM Tuning
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Rear lights keep blowing!
    To cut a long story short, the other day my rear left light was showing up on the DIS. So i changed that, then all of a sudden my rear reversing light went this was weird because it had only recently been changed! Also sometimes the DIS tells me the left reversing light is out when it isnt!
    And just now when i opened my cluster i find my P21 bulb has decided to come apart i.e. the metal has detached from the bulb!
    Now i must be doing something wrong here...
    Could someone possible give me the models/numbers of bulbs for the rear left cluster? Because it could be that the wrong bulbs were in there...
    Also forgot to add the rear left light i put in on Sunday has always gone on me again!
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    Jun 2008
    Oxford
    29
    Add Matt_Storm on Facebook
    I had this issue more so after i fitted Ebach suspension i think the extra vibration did them in - the only way around it was to fit all LED bulbs but you also need a resistor kit to stop the dash bulb fault lights coming on and the brightest Led lights are advisable, mine have been fine now for 2 + years they are a lot quicker response than standard and you get a cool multi rear light strobe show when you first start the car as it does its bulb check
    Aug 2011
    50
    mine was doing this too, blowing bulbs or else they just stopped working even tho they had jus been replaced. i ended up replacing both sidelights and brakelights both sides i just bought all new bulbs and put a tiny touch of grease on the connector part of the bulbs
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Just did the same mate, bought all new bulbs for the rear lights. Seems to be working fine now, although only time will tell.
    Could keep blowing due to my rear shocks being knackered.
    • 2004 VW Golf R32
  1. Please help! brake lights stuck on, fuse blowing! a3 2.0 tdi 2004 8p
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2014, 21:38
  2. Rear right side light keeps blowing
    By FranA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2012, 11:10
  3. rear bulbs blowing
    Last Post: 28th October 2010, 19:58
  4. Rear Bulbs blowing
    By vanbasten in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th March 2007, 17:39
  5. Blowing fuse 14 (Interior lights + Central locking) Ideas?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2006, 13:22
