AH FabricationsBadger5
    Mar 2012
    46
    Airbag Compatability
    Hello,
    This is linked to my earlier post. Im in the process of changing seats. I have the standard se seats in but have bought newer s-line ones. The car is a 2005 but the new seats are 2009. Would the age difference between car and seat mean the airbag would be rubuffed by the computer? Or will it simply just plug in without complication?
    Many thanks
    Richard
    brasiliangringo's Avatar
    Mar 2010
    544
    It's a grey area but imo it should be possible if the parts are physically identical with same resistance through circuitry (even if p/n are slightly different). I have mixed and matched part numbers on an L type in this capacity (ie seat belts and airbags and no problem with light being on / codes etc). However, it is not tried and tested, so there is no sure evidence available to support the airbags will actually work but when i did it, i used parts that where physically identical in all but their part numbers..
    Mar 2012
    46
    Hello,
    Thankyou for sharing your experience with me. If you wouldnt mind looking at my first post and casting your opinion upon it, I would be very grateful
    Regards
    Richard
    27,077
    Richard with all respect, no need to create 3 threads on the same subject, keep it to one, then all collective info given helps you better & also others who may read later
    Mar 2012
    46
    Apologies. Im new to the forum. Ill stick to one thread per subject in future. Thankyou for your advice in previous threads!
    27,077
    No worries, I'll ask Sandra to compact them all into 1
  1. 2.5tdi compatability
    By nice-one-bruv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st March 2012, 18:20
  2. Compatability of 2.8 diff
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2009, 12:07
  3. Gearbox Compatability
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2008, 19:27
  4. Wheel compatability
    By atc in forum General Chat
    Last Post: 16th May 2007, 13:07
  5. Gearbox compatability
    Last Post: 18th October 2006, 20:06
