JMB RetrofitsAH Fabrications
Results 1 to 8 of 8
Thread: Air Con Re-gas
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    Air Con Re-gas
    Found out today my air con is goosed. I reckon it needs re gassed. I know Kwik Fit do it but they made an arse of gassing the wife's MX5. So I phoned Glasgow Audi. They said £60 for a straight regas or £70 for a regas with air freshener in the gas. Has anyone had it done with the freshener in it and is it any good. Also, does anyone know anywhere else around Glasgow that gas air con other than Kwik Fit. Cheers
    L80EWY's Avatar
    Sep 2009
    331
    Need mine done to, I checked halfords and it was 90quid iirc
    Jun 2003
    World of my own
    9,813
    Don't let Audi do it they know nothing about aircon, use an aircon specialist.
    As you rightly say the Kwik fit monkeys are barely capable of fitting wheels let alone anything more complicated. They're certainly Kwik at over pressurising your aircon system but not so kwik to replace the expensive parts they've just ruined.
    Alex Turner
    Jan 2012
    SW London
    794
    what he said ^^
    What i will say is u can easily buy the air con refreshener stuff from halfords, its a doddle to do it urself, just open the can up and leave ur aircon on recirculate and full blast for ten mins. Does it all itself. Also, you can buy the can to regas the aircon and do it urself for ~£50 from halfords too. Depends how confident u are with doing it tho
    Jun 2003
    World of my own
    9,813
    Aircon regas is not merely a case of pumping more Freon into the system. The old stuff has to be drained first, and those DIY aerosols are just money down the drain. Get it done properly otherwise you could be facing a big bill.
    Alex Turner
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    Mmmm will need to look into it. Although summer in Scotland only lasts a week. It's forcast to snow up here at the weekend!!
    pod_4's Avatar
    Aug 2011
    73
    Anyone know any aircon specialists in the Glasgow area?
    Audi A3 2.0tdi S-Line Black Edition
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,458
    Quote Originally Posted by pod_4 View Post
    Try here, they are very good.
    A for Audi - Glasgow
  1. Time to Re-gas Air Con
    By malcolm1sim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd April 2007, 15:18
  2. Air Con Re - Gas
    By john2garden in forum General Technical / How To
    Last Post: 22nd August 2006, 16:47
  3. Air con gas
    By steve1975l in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2006, 22:04
  4. Intermittent start Problem and Air con gas.
    By imported_Astwell in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2004, 20:23
  5. Air con gas
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 08:01
