Badger5Monster Motorsport
Results 1 to 36 of 36
    Mar 2012
    46
    A3 Seat Swap. From se to s-line. Passenger seatbelt sensor?
    Hello.
    I am in the process of changing my standard se seats to a newer s-line seat. Now on the passenger seat i currently have a seat belt sensor. However on the newer s-line there is not. Im concerned that if i disconnect it and install the new seats without the sensor, it Will trigger a light on the dash board! Has any one came across this? If so any advice would be greatly appreciated.
    Regards
    Richard
    2005 A3 2.0 TDI SE DSG
    Mar 2012
    46
    May need VAGCOM - North East England
    Hello,
    Before I start my seat change over I need to clarify a couple of subjects. My concern is that installing my new seats may trigger either a seatbelt warning light, or airbag light. Is there anyone in the north east who does this service? Or would a dealer be able to do it at a reasonable rate?
    Please look at my other posts, any advice would be much appreciated.
    Many thanks
    Richard
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Quote Originally Posted by rsbowling View Post
    Hello,
    Many thanks
    Richard
    Welcome to ASN Richard. Where are you located in North East?
    Mar 2012
    46
    Hello,
    I am located in Ferryhill County Durham. Would you be able to help if needed?
    Many thanks,
    Richard
    Mar 2012
    46
    After speaking to a Audi mechanic earlier today, he advised me to just disconnect it from the floor and as long as the airbag is connected, all should be ok.
    I tried this tonight and a airbag light came on! I definatley took the correct lead out, but much to my suprise, i plugged it back in and the light went off!
    Everything that i have read about doesnt marry upto whats happend to me! By rights that light should of stayed on.
    brasiliangringo's Avatar
    Mar 2010
    544
    Not sure i follow what you mean by seat belt sensor as not sure why you would need to change this if you are only changing the seats ?
    Mar 2012
    46
    Hello,
    Apologies for not being so clear. I have currently a pressure pad in the passenger seat and a cable to the belt buckle. The new one does not have this facility. Any advice or logic would be great.
    Many Thanks
    Richard
    Mar 2010
    544
    Im not familiar with your set up but as a general rule, if something is missing from the circuit that was there before, the ECU will see it as an open cicuit (as nothing connected) and throw a code and dash light.
    You can close that connection by bridging the two wires together +/- ( the plug the sensor connects to) with a suitable resistor in between to simulate the missing component being there - try 3ohms.
    Not sure if that helps.
    This is similar to fault finding on an airbag system before actually replacing expensive bags, you bridge the connection with a suitable resistor to see if fault goes away or stays..
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    I am in Scotland. Click on the link below, its a map with users that have vcds. When you click on the baloon in your area, a members details will display. Pm members close to you to see if they can help you out. Audi-Sport.net VCDS Users - Google Maps
    Mar 2012
    46
    Thankyou very much for your help. Much appreciated.
    Mar 2012
    46
    What you say makes sense. How would I go about making this resistor? Pardon my lack of knowledge!
    Thankyou
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Any problems just give me a shout Richard.
    Mar 2010
    544
    You can buy them on the net, just do a google search. Then you put one end in each end of the connector. Ie the ecu end of the plug. If that resitance works you can cut the wires and the connector out and crimp or solder in place then tape up. You will get the idea..
    27,129
    Dont bodge the setup, just get someone local to disable seat belt warning system with vcds, also you could always strip the seat down & swap the pads across with the loom aswell.
    27,129
    Send a PM to Jb00 or A8Tech, they're up there somewhere.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    Hi Richard, I'm in Hartlepool and I've got VCDS.
    I've just had a little browse through your previous threads.
    VCDS has a function to disable the airbags in the seats and although I've never done this in an Audi before when I did it on a Seat Ibiza the Airbag light flashed for 15 seconds when you started the car and then disappeared.
    Like a previous poster also said, you can marry the two terminals from the airbag plug to close the circuit but also rightfully said a resistor must be placed in the middle to trick the circuit.. no idea what ohm resistor will be needed though.
    I'm more than happy to have a crack for you and see what we can do, but can't make you any promises
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    But also, as you're transferring OEM seats you shouldn't have to "trick" any airbags... it may be a cause of different pins etc which could be worked out using Elsa.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Quote Originally Posted by jb0o View Post
    Thanks Jonny, I couldnt remember where you were.
    HIGGINS's Avatar
    Mar 2010
    523
    If your fitting after market seats you will need 4.7ohm 1/2W 5% resistor's
    Selling MY11 rear lights, message me for a price
    Mar 2012
    46
    Thankyou ever so.much for the responses! In particular jb0o. I could well take you up on that offer if i can't get it to work. Also has any one got a idea of where to get that resistor? They are genuine audi seats from a 09 plate.
    Thankyou once again
    27,129
    You wont need resistors, if you get it coded properly by say Jonny.
    Mar 2012
    46
    Thankyou for advice. Also thanks nhn. How easy would it be to stripb the seat? Any tips?
    27,129
    Well if you have experience of this type of thing, its not to bad, just take time & patients, mostly plastic retaining strips that need to be manipulated out of the runners, then swap bits over & refit, whereabouts are you located?
    Mar 2010
    544
    Im curious to know where i can find a guide to this on Ross tech's site as never knew it possible. I did a google but to no avail. Thanks.
    Mar 2012
    46
    Ok thanks. I have the patience, i think! Im in Ferryhill county Durham. What does the pressure pad look like? Is it thin or does it come with some gubbins?
    Regards
    27,129
    Sorry yes my bad, you already stated where you were.
    Regardless what it looks like, you'd have to remove the same bits anyway to get to it, so should be obviously once out, just follow the iirc 2 pin loom.
  28. #27
    Mar 2012
    46
    Thanks Johnny. By pins, you mean the male and female connectors for the airbag to the car? Also may I ask what is elsa? Regards, Richard
  29. #28
    27,129
    I think you should be fine as I had a later set in my car which plugged in 100% to airbag system.
  30. #29
    Mar 2012
    46
    Thanks for the reply. Are the airbags normally trouble free? For example, if the wire and connector you can visably see from the seat looks ok, is it normally ok to install? Or are they known to fail?
  31. #30
    Mar 2012
    46
    Hi,
    I have installed the new seats this weekend with great success. I decided to swap the pressure sensor over and it works with no lights on the dash board.
    The seat came apart easily and went back together just the same, and doesn't look like its ever been apart.
    I have swapped the under seat storage units into the new ones, and also the plastic backs to the seat came(with nets in).
    If any one is doing anything similar and needs advice ill.be happy to help.
    Im a carpenter and not a car expert, but the whole interior took me about 4 hours, including swapping bits from seat to seat, and cleaning everything i could see.
    The lesson i have learnt from this is to keep things as standard as possible, not rely on having to get a computer to fix it. As i have lovely new seats with the sensors all working and airbags all sorted.
    Hope my thread has helped, and may help others. Thankyou to everyone who gave advice.
    Now all i need is some nice 17" alloys!
    Regards
    Richard
  32. #31
    A3 Sportback 2.0 T FSi
    Jul 2011
    Congleton
    67
    I have just swapped my rather warn Sport interior for a nearly new half leather S-Line and had the same issue with the passenger seat not having the same sensor. I got round it by shorting the pins out to trick the system into thinking someone is sat in the seat with the seatbelt on (stops the anoying bong).
    I am very interested in more information on swapping the sensors over and then I can decide to follow your lead.
    Thanks in advance.
  33. #32
    Mar 2012
    46
    Thankyou for viewing my post.
    Well to start off, your old seat and new seat upside down on the floor, and if you grip the seat and minipulate the plastic trim which is attatched to the fabric, and hooks over the metal frame, off the seat. Then once thats free, on each 'rib' of the seat there is little plastic 'arrow head clips'. Simply work these out until you get to the back of the seat, revealling the sensor. The sensor is a flat, plastic thing with wiring coming off it. Once removed from the old seat, position on the new one and route it through the seat base so the cable is underneath. You may need to cut a slot in the sponge to get the cable through. Once you have done that put the seat back together and simply plug it in.
    If you have a good work space and time set aside this is a really straight forward job, and keeps everything as it should be! Once you have the seats out there is no wiring to unplug, the sensor is all one unit. Also what i did is take the under storage from the old seats and put them on my new ones, also swapped over blemished parts.
    Also before you put the key in the ignition make sure all connections are together well, and take care when routing them, to make sure they wont interfere with the seat moving.
    Hope this helps
    Regards
    Richard
  34. #33
    Jul 2011
    Congleton
    67
    What about the cable that goes off to the seatbelt?
    My wiring harness has two cables, one goes to the seat occupency sensor under the seat the other goes off towards the seatbelt (presumably to sense if the seatbelt is worn).
    Did you also have "fun" with the doorcards?
    I have just spent the day transfering my sports ambient lighting and puddle lights to my new S-Line interior doorcards. I had to cut holes in the bottom of the cards to take the puddle lights and transfer the whole handle assembly to get the slot for the handle light. Then once I had undone and done back up about 20 screws I had to transfer the wiring looms from one door card to the other, after doing this 4 times I was finaly done!
    I am very pleased with the final result the car actualy smells new inside.
    Thanks, Geoff
  35. #34
    Navisace's Avatar
    May 2009
    Birmingham, central
    51
    hi rsbowling
    i have swapped my seats over to s line ones but was wondering if you could advise me on how to swap over the seat backing with the netting please. i am worried that i might break something.
    my seats were a stright swap as both had same cables.
    will be have a look at the door cars as i need to bring over all wiring and lights just like gdbarret .not looking forward to that.
    cheers
    The more i know the less i understand...
    2013 Audi A3 2.0 Tdi 150 S Line DSG, pan roof tech pack comfort pack light pack sat nav
    2012 Audi A3 2.0 Tdi 140 S Line DSG Black Edition
    2007 Audi A3 2.0 Tdi 170 SE DSG with all the S Line bits vortex skirts
    Gone but not forgotten
    2009 Audi A4 2.0 Tdi S-line Final Edition ( 4 year old only covered 4750 miles)
  36. #35
    Mar 2012
    46
    Hi,
    Thanks for viewing. As for the seat buckle, yes i did have a cable running from that as well as the occupancy sensor. If your new seats dont have it just swap the seatbelt stalk over, is just one multi-spline bolt. These both need to be fitted. My car already had ambiant lighting in so unfortunatley cant relate to the work you have done!
    The seat backs came off easily, but you could easily damage them. I got a wide chisel and fed it into the top of the back, then moved it until it hit something, this was one of the three clips that hold it on. i just turned the chisel and it popped off, if you feel as though its splitting the back, try another position. The bottom of the back just hooks in.
    Good luck with your efforts!
    Hope this helps.
    Regards
    Richard
  37. #36
    Navisace's Avatar
    May 2009
    Birmingham, central
    51
    thanks for the detail.
    took me 5 mins to do swap
    door cards next but when weather is a bit better
    nav
  1. Audi S3/ S line Rear Seat Swap Has Armrest & Cupholders
    By EvolutionV in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2011, 14:32
  2. Drivers seat won't go as low as passenger seat
    By spitfiredealer in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2010, 16:01
  3. Passenger Seat
    By smythey1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th February 2010, 19:25
  4. Passenger side seatbelt! Anyone know where i can get 1?
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2007, 15:42
  5. Full 3-point seatbelt in rear middle seat
    By dermot in forum Detailing
    Last Post: 7th February 2004, 22:13
