Sky InsuranceJMB Retrofits
    Jan 2009
    Canterbury Kent England
    Climate control AUTO lamp not available
    Just thought I'd share this tip. I recently sold my 55 plate A3 1.9TDI . The day before the sale my air-con packed up. The ECON lamp was on permanently and I was unable to select AUTO. I had the system gas pressure checked which was OK, then the aircon guy said the fault was possibly the pressure switch. I bought one (£14) on the day of the sale ripped off the front bumper left-hand access cover and worked through the gap. I've since found out you can use a crows-foot spanner from the top. Switch unscrews from a Schrader valve so you don't lose system pressure. New switch fitted , everything works again. Car sold that evening. Bought another A3 cos I like them.
    27,129
    Another thing to check for this issue with econ on, are the fuses, as 1 blows & causes the same description
  1. Rear lamp control unit
    By b16 will in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st May 2011, 12:30
  2. How do I control both zones with climate control?
    By mrviews in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2010, 20:03
  3. Auto Climate Control, Problem Blowing Cold Air
    By mystic.bertie in forum General Chat
    Last Post: 17th March 2009, 15:59
  4. Replies: 3
    Last Post: 13th July 2007, 10:53
  5. Traction Control Lamp
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 08:51
