A3 Sportback springs or Sline sPrings help
ruairi83
Garage
ive got a 2009 a3 sportback tdi.
Ive been offered 2009 a3 sportback tdi sline springs.
whats the differnce in ride height?
would they be worth putting in and would they be hard than normal springs?
thanks
anyone knwo about these?
had someone say they drop 25mm... could this be true?
does anyone have an idea how much sline springs would drop the car? 10mm, 15mm, 20mm etc? someone must know...
hi depending on what spec of car you have, s line spring give a 25mm drop over the standard/se car. think they are 10mm lower than the sport spec. sure someone else will pitch in
Are you just lowering the car, or does ride quality matter.
Not sure S-Lines are renowned for great ride.
Think Blob's right ref ride heights
i just want it a bit lower but not too stiff lads.thanks for replys.
I believe the S-Line is a little lower than standard. The sport is stiffer than the standard as well so could only guess it's a little lower but nothing you can really notice (10mm?).
688
579
DPM
12
936
12
DPM
