Was he trying to sell you a secondhand Audi without Bose?Some one told me at an audi dealership that the bose isnt as good as standard system, surley this cant be true ????
Bose is in the A3 Black Edition as standard and available as an option: I think it's standard on S3 and RS3 base models, but don't hold me to that.
As with any audio system, it's only as good as the source - if you're running 128kbps MP3s through the headphone jack of a phone, it's going to be ****. If you get some proper music (I use apple lossless rips of CDs, via my iPod's dock connector and AMI) then it's decent.
It needs a little tweaking, the top end is a little too high for my taste - turn the treble down (NOT the bass up) and job done. It's also a bit nicer with the fader set with a slight rear bias.
It's not as good as the B&O system in the higher end cars, but it's really not that much difference. If you're a sound engineer you'll be able to tell. If you're an audio enthusiast then you might be able to, but you'll probably only notice at those times when you're listening for it - I'd say that if your home speakers cost less than £600 for amp, sub and a couple of speakers, you'll probably find that your car sounds better.
Worth having, and better than the stock system by a decent margin: but as I said, sort your source out first - if you play **** quality music on it, don't be surprised when it gives you **** quality back. Audio rule #1 - sort the source component before the playback hardware.
Bose issues (Bose Autopilot GALA) can be improved with a bit of VCDS coding, but I have to say whilst it sounds better than OEM basic, it falls way short of my old system (full Alpine with dual amps and DVC sub).
Got any more info on this Warren? It is starting to pee me off.
AS far as fitting Bose grilles to a non Bose car goes - ask paddy and I'm sure he'll give you an opinion on that one! And I agree, the Bose does sound marginally better than the harmon kardon I had in my M3, I'd rather have the new B&O gear that's in the new 3 door a3 tho.. That's just design porn! Nearly as nice as the home equipment..@quattro - I think I just got a bit too excited when I saw your illuminated BOSE grilles. Were they a lot of work? Not a fan of fitting bose grilles to a non-bose car though, where does it end?! S3 badges on a TDI?
Having had both, the BOSE is substantially better than the stock setup. I'd also go as far to say it's better than the Harmon Kardon (sp) setup in my mates beemer, YMMV depending on the sort of tunes you listen to.
Definitely go with the bose.. I have spent many thousands in the past on ICE (for the car, not crystal meth before anyone makes any wisecracks!) But the Bose sound quality is more than adequate and substantially better than the standard.... Plus you can get these:
I guess it depends on how much of an audiophile you are.. Take some Dr.Dre down to the stealership and crank it up in both systems, whichever gets them shouting at you quicker is the winner!
That's tempted me sooo many times Warren! I thought about the illuminated glove box handle thingy too, but mine already has "Quattro" engraved and I thought illuminating that too might be a step too far.........
I agree with you here.. On mine it is piano black so you don't notice the red led at all until you reach towards the centre console or rearview, at which point your hand starts glowing red!I think you're right.
One thing I've noted in the 8P3 is that the interior light pack seems less noticeable at night on the centre console area and only the gear gaiter surround (which is alu in our car) shines any of the red LED light back. It needs something, but can't find anything tasteful!
BOSE, is designed and manafactured by Bang and Olfson...Premiership sound quality.
The term BOSE, is marketed for B.ang & O.lfson S.ound E.ntertainment
Bose is nothing to do with B&O, it is a privately owned company founded by Dr Amar Bose from MIT, I'm guessing here but I think the term Bose is derived from his name
