    41
    Auxiliary Heater (Z35) - DTC
    Hi all
    I have done a scan for DTC's on my Audi A3 2.0 TDI 2004 and I have the following 2 DTC's. I didn't even think my car had an Aux Heater? I have looked through the manual and the fuse (F30) is the only thing that mentions the Aux Heater, and there isn't even a fuse in that spot anyway. Can anyone advise?
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    1 Fault Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 183448 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 18:22:11
    Freeze Frame:
    ON
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    Rick
    audigex's Avatar
    Jul 2011
    555
    I saw mention of it in my manual - didn't really pay attention because it warms up reasonably quickly, I've got heated seats anyway, and it's never cold enough here to need it. Could it be right that ere are two additional heaters possible, one in every TDI (because it takes longer to warm up) and one for cars exported to cold countries?
    Ibis White A3 Sportback Black Edition.
    2.0 TDI (170) Quattro
    Pics
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Auxiliary Heater mentioned in your VCDS reading warms up the cold air before the coolant reaches the temperature, heating up the air coming through the air vents as soon as you start the engine.
    VCDS USER
  1. Webasto auxiliary heater retrofit
    By nevergivup99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th December 2011, 12:20
  2. Auxiliary Coolant Pump
    By jimbobery in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2009, 22:21
  3. Audi a4 auxiliary input
    By flyersphan585858 in forum General Chat
    Last Post: 10th July 2007, 18:48
  4. Electric auxiliary air heater
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2007, 19:21
  5. Auxiliary heating
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2006, 21:45
