AH FabricationsJMB Retrofits
    Jun 2011
    Melbourne
    230
    Rear springs not sitting the same (H&R) after brake install
    Hi All,
    Noticed that the car handling a bit odd after finishing up with the brake rotors and pads install. It kind of "limps" at very low speeds and a bit jumpy over bumps and also steering rattle at high speeds. Braking is smooth so its not brake shudder. Had a look around and noticed that the rear spring on the driver side (British/Aus) is compressed when car on ground, while passenger side is loose. Did one of them slip out of position or something? is it the passenger side? should that look compressed like the driver side (basically 3 or 4 coils touching each other with last two away from the rest).
    Would it be possible for someone with a 25mm drop H&R springs have a look and let me know please?
    Many thanks
    Dec 2008
    278
    Quote Originally Posted by NCRAW View Post
    Hi All,
    Many thanks
    Hi mate,
    You don't mention what car you've got, but I've just stuck my iPhone under my 2008 S3 which is sat on the H&R Cup Kit (25mm drop) and my rear springs sound like your driver side ones - the top 4 coils are touching, the bottom two are not.
    Edit: Bad picture added:
    Cheers,
    Rich
    Jun 2011
    Melbourne
    230
    You are a legend bro. thanks for your help. Sorry I'm used to having a signature on ozaudi.com. Car is a 2008 S3 2 door. awesome pic. yep that looks exactly like my driver side which tells me the shock is fine too. Ok so must be the passenger side that slipped out or something. better get it checked today. dont want to leave it long. might cause issues after a while.
    Quote Originally Posted by essIII View Post
    Hi mate,
    Cheers,
    Rich
    Dec 2008
    278
    No probs pal, happy to help. Hope you get it sorted!
    Dec 2008
    Georges Hall NSW Australia
    29
    Haven't really had a good look under the S3,but I know with the Polo GTI if you jacked both rear wheels off the ground,the springs practically fell out by themselves.
    Check that they're located correctlty and not misaligned somewhat.
    Len
  1. 2002 S3 Rear springs & shocks
    By mattyboy199 in forum A3/S/RS Parts
    Last Post: 28th November 2011, 14:26
  2. Broken rear spring - are BAM rear springs same as AMK rear springs?
    By chris-edin in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2011, 23:13
  3. Rear Brake Pads & Disc Replacement
    By maddoggydawg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 20:43
  4. Rear Brake Pads & Caliper Tool ???
    By roy_barber99 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2008, 21:35
  5. DPM Autostyling Weitec Shocks/Springs & H&R ARB Install Cost??
    By OvettC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2007, 00:20
