Results 1 to 12 of 12
    Feb 2012
    North East
    81
    Single or double din?
    Hi,
    I have a new diesel Black Edition due to be delivered next month, it will be fitted with a Concert radio and Bose. I want to change the radio for the mk2 RNS-E. Will my car have a single or double din? I understand the job involves more work if it's a single din.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    it will have double din. straight swap
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Jan 2012
    SW London
    794
    get urself 4 of these
    PC5-93 European Release Removal Stereo Keys Radio CD (5032296005938) | eBay
    Then it really is a very simple swap. The keys only go in one way and u'd need two ppl to comfortably remove it, u need to squeeze all four at the same time to release the stereo. If the stereo isn't coded, and is in perfect condition you should be able to sell it on at a decent price.
    Apr 2009
    Florida (previously Liverpool)
    655
    not ...*QUITE*... a straight swap.
    You'll need to move the 'BLOSE' pin, and there's also the matter of updating the ampliffiers in the hatch to avoid the 'ZF short-to-ground' antenna fault, but in terms of FITMENT, then yes, it's a fairly straightforward changeover.
    Feb 2012
    North East
    81
    Thanks for your replies guys. I will by a unit and get that OEM Retrofit company in Bradford to install it. They only charge £70 for the service. Can't sell the concert as it's a company car and have to put it back to standard spec when I return it after 5yrs or 100k miles.
    Andy Crooks's Avatar
    Feb 2011
    Worcester
    938
    Follow Andy Crooks On Twitter Add Andy Crooks on Facebook
    Found the thread I was after
    I'm wanting to do the same thing and I have the concert radio - my 1st question answered already
    Secondly I have Ipod connection in the glove compartment, this would affect the sat nav would it?
    thirdly would this fit my car Audi A3 S3 Media MK2 RNS-E PU sat nav LED RNS - E 2011 | eBay
    Its a 61 plate so I'm guessing that's a 8P chassis?
    would it need vag-com on to it as well if it kicks up any faults and would it need coding?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    You really should get the RNS-E units coded using VCDS otherwise you will have errors on your car computer and yes, you need to change the BOSE pins and you will probably have AUX in as well that will need connecting properly too.
    You also need to consider upgrading your antenna's that are located in your boot lid as well if you want it done properly.
    Regarding the iPod connection in the glove box. Yes, this can still work but it still won't display track names on your head unit. I would recommend upgrading it to AMI which enables track names, budget permitting of course.
    Feb 2011
    Worcester
    938
    how much should i roughly spend on doing it without spending a fortune i was thinking around £500ish and where abouts are they located in the boot lid then? im not worried about display names if i dont like the track i just skip it haha
    I would assume that i would be able to find most of it on the bay
    these the antennas your reffering too Audi A3 A4 A6 TT Allroad RNS-E radio antenna aerial adapter double fakra ISO | eBay
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    You probably need to spend about £1000 if you want it done properly but if you have that budget then I wouldn't worry about the antenna's at the moment although you might find in certain areas your radio not working very well. I'm only going on what NHN said when he fitted my RNS-E unit for me a couple of weeks ago. Personally I wouldn't buy those units off ebay unless they look like genuine sellers as you don't know the history of the units - it could be stolen, who knows. NHN can sell you the unit I think.
    Feb 2011
    Worcester
    938
    ah yes thats a good point, DEFINATLY dont want to be going down the buying stolen items route and ok, i need to save up the pennies 1st but i think for me it would be a good mod as i use a sat nav regularly
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    Send NHN a PM, he's the man when it comes to this stuff, I can assure you.
    Oct 2011
    23
    Did you use the OEM Retrofit company in Bradford? Are they genuine good guys or not.
    thanks
  1. ANYONE HELP?? Head Unit - Single Din to Double Din Conversion
    By rdhighoctane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2013, 23:03
  2. changing audi single din stereo for double din sat nav.....
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th January 2013, 09:45
  3. Replies: 2
    Last Post: 24th November 2010, 20:18
  4. Retro fit RNS-E from single din to double din
    By Kevin Edwards in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2008, 08:28
  5. Nav+ and Bluetooth Retrofit: single-DIN to double-DIN conversion
    By jesters3 in forum In-Car Entertainment
    Last Post: 14th May 2008, 13:12
