Chris NottSky Insurance
    JK
    Mar 2012
    chertsey/surrey
    16
    steering angle sensor
    Hi all, new to this forum so be patient, im hoping someone out there can help get my car fixed ! esp and abs lights wont reset.
    a3 3.2Q dsg 31k miles 04
    I bought car as part repaired cat D ( the guy said it only needed 4 wheel alignment, what was I thinking ) front damage driven over curb hard, any way I ended up supplying the accident repair garage with a 2010 subframe, arms and steering rack as it seemed like option that would solve a lot of unknown problems and was less labour than changing one bit at a time. The 2010 rack needed a wiring pack from Audi to fit and they also replaced some wiring to the ns abs with Audi parts, unfortunately their diagnostics guy has spent hours and 5 visits to try and reset dash lights and is getting nowhere. He thinks the new rack has steering angle sensor built in and needs to disable one in steering column (something I read on the forum and told garage) but his equipment will not let him. Don't know what system he is using. The car has 2011 wheels on as others must have been damaged and not original steering wheel.
    The car drives OK with power steering working but lights wont reset. Have tried Ross techs ESP Steering Angle Sensor Calibration procedure and the 4 wheel geometry has been done spot on.
    The car has been in garage since November and I have not had chance to use it yet, please help !!
    Fault codes are
    2546 steering limit stop
    778 steering angle sensor
    27,099
    I could have a crack at it as I think I know how to get it sorted out.
    PM me & we can arrange a visit.
    JK
    Mar 2012
    chertsey/surrey
    16
    newbie cant do a pm !
    ElliottB's Avatar
    Audi A3
    Nov 2011
    Hull
    144
    I had a steering angle sensor issue. I had it reset twice and it came back, the dash flashed up with ESP fault - see manual and the traction control light came on the left hand side and a yellow steering wheel on the right hand side and the power steering went really heavy. Had it done at audi, been fine ever since
    Audi A3 2.0 TDI - S3 Intercooler - Darkside Developments Hard Pipe Boost Kit - EGR Delete - Milltek Non-Res Decat Exhaust System - Performance -Torque Custom Remap 187BHP + 335lb/ft
    JK
    Mar 2012
    chertsey/surrey
    16
    thanks for help, mine is to do with damage or incompatible parts issue, will try Audi as last resort. Steering is assisted and light with mine and abs works just the lights on and fault codes. Someone clever with vagcom could fix it easy im hoping ? any one want a go? otherwise i will buy a lead and DIY !!
    27,099
    Sorry fella was on route to Italy as birthday tomorrow, I'll catch up on my PM's today
  1. Steering Angle Sensor
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2011, 20:38
  2. Steering Angle Sensor
    Last Post: 18th November 2011, 23:01
  3. steering angle sensor
    By dubber dude in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2011, 22:53
  4. Steering angle sensor
    By s3_stig in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 13:51
  5. steering angle sensor
    By Techimike in forum General Technical / How To
    Last Post: 4th December 2008, 09:22
