AH FabricationsBadger5
    Jan 2011
    119
    audi a3 8p 2.0 tdi 3 door rear hub removal, abs fault??
    Hi Guys,
    had my MOT today and failed because the abs and traction control light was on, something i have been putting off for ages now, i fitted a new rear abs sensor as vagcom threw up the rear sensor error, i had such a struggle getting the old one out that when i was trying to remove it with a screwdriver i think i damaged the ring on the other side that i think is attached to the bearing, is this right? Anyway i need to remove the hub and fit a new one apparently because the abs ring is attached to the hub/bearing. I have managed to get the bolt undone for the bearing but i just wanted to know what kind of bolt is used to hold the carrier on and what size? is it a spline? I also need to remove both rear pads and free them up as it failed on the rear callipers binding also. Is there a how to guide on how to remove the rear hubs/calliper, bearing etc?
    Any help with this would be much appreciated.
    Chris
    Aug 2011
    56
    Hi mate, regarding you abs and traction control light, did you get every now and then a red light flashing too?? As I'm having this problem?
    Cheers manni
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Get it scanned with VCDS mate.
    VCDS USER
    Jan 2011
    119
    Hi Manni, i never had the flashing light, i have vcds and have scanned it, says rear right sensor inplausable signal, i have managed to take the hub off and the back of the hub is badly corroded. Im pretty sure thats what the problem is.
    Aug 2011
    56
    Cheers mate
  1. Rear door card removal (3 door)
    By Dec in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2012, 06:53
  2. Rear ABS Wheel Sensor fault reported
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 18:32
  3. Help - rear abs sensor removal s4
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2009, 19:42
  4. rear door fault
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th June 2007, 22:32
  5. rear door card removal A6 Saloon
    By daver in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th August 2006, 13:59
