Volks AutosAH Fabrications
Results 1 to 20 of 20
    Mar 2010
    54
    Adaptive zenon start up
    Hello guys I have adaptive bi zenons the lights work fine but just wondering if they should move side to side when the car starts up because at the minute they just go up and down I have vag com if it can be set in there many thanks
    Aug 2007
    375
    Hi,
    I have adaptives... the lights go up and down then left and right.
    Hope this helps
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by neilwaterhouse88 View Post
    Im on my 3rd 8p. the xenons only move up and down for self levelling. it's normal.
    Ive seen VW passats with these side to side up down warm up regime but pretty sure the S3 doesn't have this feature. [I may be corrected ]
    It does look pretty cool though when they do go mad when you switch them on though
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by drnutta View Post
    Hi,
    I have adaptives... the rights go up and down then left and right.
    Hope this helps
    Just the rights?? I've never noticed this? :-/
    Mar 2010
    54
    Ok that's good thank u I just wondered if I had it set up wrong, would be cool if it could be set up but not worried if it can't be,
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    I'm off outside to switch these bad boys on, Im sure I'm not going mad!
    Mar 2010
    54
    Mine just go up and down deffo, let me know wen u check yours
    Aug 2007
    375
    corrected sorry... at start my lights go up and down then left and right
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    I'm only seeing up down motions...
    27,129
    You need to check the headlight modules fitted in module 55 to determine what versions are fitted, usually adaptives go LR aswell as Up/Down, normals just Up/Down
    Mar 2010
    54
    If I check this is there anyway I can change it to make them go l/r or is it just that only certain modules will be able to
    27,129
    You cant make normal bixenons into adaptives, there's wiring, electronics & headlight differences, so would have to be swapped out, modules changed, rewired & coded to suit.
    You can go into vcds & test the adaptives with showroom effect if adaptive.
    Assume its a genuine cable.
    Mar 2010
    54
    Yes it's a genuine cable, they work on showroom effect but just don't go side to side when I start the car up
    27,129
    You got a log of the car we can see?
    Reesy's Avatar
    East Sussex
    3,604
    Side to side will be for adaptives, as mentioned above, as this is what adaptive lights do...
    Up and down is for normal xenons as that is all that the lights have to adjust whilst on the move.
    Mar 2010
    54
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Monday,12,March,2012,21:32:30:41856
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 75 77
    VIN: WAUZZZ8P8AA037955 Mileage: 70160km/43595miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    75-Telematics -- Status: Cannot be reached 1100
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 056 S HW: 03G 906 021 AB
    Component: R4 1,9L EDC G000SG 2917
    Revision: --H11--- Serial number: AUX7Z0I6FNL0II
    Coding: 0000071
    Shop #: WSC 66565 257 00032
    VCID: 3776243D4656A5B
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 1342201209250001C81404E9901E00813800
    Shop #: WSC 06314 000 00000
    VCID: 7EF8F119E9EC543
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
    Component: KlimavollautomatH09 0140
    Revision: 000052 Serial number: 8P0820043BK
    Shop #: WSC 00000 000 00000
    VCID: 76E8E93901DC1C3
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
    Component: BCM PQ35 M 104 0575
    Revision: 00104 AH
    Coding: 46000A2BB005F200207041E0050009CC435E25AA305DD109E4 0048840040
    Shop #: WSC 01211 210 01254
    VCID: 326015296D34403
    Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00DD13
    Subsystem 2 - Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Subsystem 3 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Subsystem 4 - Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    5 Faults Found:
    00924 - Relay for Headlamp Cleaning System (J39)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 4
    Fault Frequency: 254
    Reset counter: 169
    Mileage: 63327 km
    Time Indication: 0
    Date: 2011.12.09
    Time: 11:43:49
    Freeze Frame:
    Term 15 Off
    Voltage: 11.85 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    01565 - Luggage Compartment Light (W3)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 141
    Mileage: 69322 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.40 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 250
    Mileage: 65085 km
    Time Indication: 0
    Date: 2011.12.26
    Time: 17:22:08
    Freeze Frame:
    Term 15 On
    Voltage: 12.10 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    01504 - Bulb for License-Plate Light (X)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 141
    Mileage: 69322 km
    Time Indication: 0
    Date: 2012.03.01
    Time: 18:17:17
    Freeze Frame:
    Term 15 Off
    Voltage: 12.20 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 148
    Mileage: 69558 km
    Time Indication: 0
    Date: 2012.03.05
    Time: 19:28:38
    Freeze Frame:
    Term 15 Off
    Voltage: 12.15 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
    Component: Airbag AU1042 H06 0140
    Revision: -------- Serial number: 003FB002DJ1L
    Coding: 303142413039303030384A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 4FA67CDD16C60DB
    Crash sensor for side airbag; driver side:
    Serial number: 34928RB400004F35451J
    Crash sensor for side airbag; passenger side:
    Serial number: 35028RB400004EE3CD90
    Crash sensor for side airbag; rear driver side:
    Serial number: 35128RB400004F35452D
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35228RB400004F262B0G
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB400004F25778S
    Crash sensor for front airbag; passenger side:
    Serial number: 35647RB400004F25785R
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0004042
    VCID: 468859F931BCCC3
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
    Component: KOMBIINSTR. VDO H02 0980
    Revision: D0H02002 Serial number: 2246I002005231
    Coding: 0004458
    Shop #: WSC 00484 210 96978
    VCID: 40844FE11398E23
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AA HW: 1K0 907 951
    Component: J533 Gateway H16 5223
    Revision: H16 Serial number: 4120K0972000C8
    Coding: E9811F06700602000101
    VCID: 66C8B979517CEC3
    1 Fault Found:
    01302 - Control Module for Telematic (J499)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 208
    Mileage: 63327 km
    Time Indication: 0
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H02002 Serial number: AUX7Z0I6FNL0II
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 C HW: 8P0 035 193 C
    Component: RNS-E PU EU H03 0200
    Revision: 0000005S Serial number: AUZBZ7K6000011
    Coding: 0205753
    Shop #: WSC 51462 133 17982
    VCID: 30641F21A338723
    3 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 66570 km
    Time Indication: 0
    Date: 2012.01.24
    Time: 13:32:03
    Freeze Frame:
    Voltage: 10.50 V
    Mileage: 70160 km
    Count: 1203
    Clock: 21:28
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 208
    Mileage: 63327 km
    Time Indication: 0
    Date: 2011.12.09
    Time: 11:42:30
    Freeze Frame:
    Mileage: 63320 km
    Count: 912
    Clock: 11:42
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 208
    Mileage: 63327 km
    Time Indication: 0
    Date: 2011.12.09
    Time: 11:42:13
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
    Component: Tuer-SG H04 0100
    Coding: 0000564
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 H
    Component: EPS_ZFLS Kl. 232 2901
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    VCID: 2F661C5DBE066DB
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 E HW: 8P3 035 382 E
    Component: AB2 SUBWOOFERBOXH31 0160
    Revision: 00007 Serial number: 92157948617669
    VCID: 356A2E355C5A57B
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
    Coding: 0000564
    VCID: 479654FD36B6D5B
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4L0 910 357 HW: 4L0 907 357
    Component: AFS 1 H01 0040
    Revision: 00000001 Serial number:
    Coding: 0000028
    VCID: E9D23245C06243B
    Part No: 7L6 941 329 B
    Component: AFS-Modul links H03 0004
    Component: AFS-Modul rechtsH03 0004
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205753
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 66570 km
    Time Indication: 0
    Date: 2012.01.24
    Time: 13:32:03
    Freeze Frame:
    Voltage: 10.50 V
    Mileage: 70160 km
    Count: 1203
    Clock: 21:28
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 208
    Mileage: 63327 km
    Time Indication: 0
    Date: 2011.12.09
    Time: 11:42:30
    Freeze Frame:
    Mileage: 63320 km
    Count: 912
    Clock: 11:42
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 208
    Mileage: 63327 km
    Time Indication: 0
    Date: 2011.12.09
    Time: 11:42:13
    Address 75: Telematics
    Cannot be reached
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0600
    Revision: 00000000 Serial number: 00000005109081
    Coding: 0011402
    VCID: 75EAEE351CDA17B
    right i think i have done that correct there are a few fault codes on there i know one is because i have fitted the sta nav and one is because i have the phone prep set to high so the phone book and missed calls ectshow on the screen
    27,129
    I'll test some in the near future, iirc last car I did for these lights didnt do L/R everytime in use.
    Quote Originally Posted by Reesy View Post
    I have adaptive xenons and my current MY12 Sportback and I also had them on the previous 2009 Sportback and I don't think I ever saw them move from side to side on start-up. Up and down but never side to side.
    Dave R (h5djr)
    27,129
    They do act in this manner dave, just not all the time iirc from others have used & installed, however my prefacelift adaptives did it every time.
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    367
    Seems like a bit of a mix and match, the adaptives on my 8P2 S3 don't do the side to side on startup.
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
  1. Zenon head light bulb blown!!!
    By A4 PC in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 7th June 2012, 22:26
  2. My zenon warning light
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2008, 11:08
  3. Zenon fogs?
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2007, 13:58
  4. Zenon Light Problems
    By shollis in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2007, 10:37
  5. zenon headlights
    By garratt83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2006, 16:09
