EM TuningMonster Motorsport
    Dec 2007
    35
    Clutch change - 3.2 Quattro
    Evening all,
    My clutch is going to need replacing shortly. I've found a guide online for changing the clutch on a Mk4 R32. Can anyone who is familiar with the two cars or the procedure of changing the clutch, let me know if they think an R32 guide would be close enough?
    I have done clutches before, but only on older/less sophisticated cars.
    Also, What is the normal procedure with the fly wheels on these? Do people change them as a matter of course?
    Thanks for any thoughts.
    Jan 2011
    northants
    165
    r32 is similar
    its easier to remove subframe completely to gain access
    if you have gearbox out do flywheel as its preventitive maintenance if it goes in 6mths you will kick yourself
  1. Clutch change
    By Keiran in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2011, 01:41
  2. B6 1.9 TDI Clutch change how to?
    By Oak Dub in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2011, 12:29
  3. quattro clutch change (how long)
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2009, 15:59
  4. A3 quattro clutch + flywheel change (knackerd slave cylinder)
    By daveeeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2009, 14:37
  5. Clutch Change
    By tominski in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2006, 09:02
