Clutch change - 3.2 Quattro
PhilPD
NULL
Evening all,
My clutch is going to need replacing shortly. I've found a guide online for changing the clutch on a Mk4 R32. Can anyone who is familiar with the two cars or the procedure of changing the clutch, let me know if they think an R32 guide would be close enough?
I have done clutches before, but only on older/less sophisticated cars.
Also, What is the normal procedure with the fly wheels on these? Do people change them as a matter of course?
Thanks for any thoughts.
r32 is similar
its easier to remove subframe completely to gain access
if you have gearbox out do flywheel as its preventitive maintenance if it goes in 6mths you will kick yourself
863
639
7
3K
d2w
857
DPM
