Volks AutosChris Nott
Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By Paullie
  • 1 Post By Sidhu88
Thread: ill fitting rear light clusters
    Feb 2012
    dorset
    7
    Help, my rear light clusters don't seem to fit very well, there is a big gap between the body work and the actual light cluster so when it rains or i go through the car wash water enters the boot area and the the wiring loom gets wet. Is there supposed to be a seal around the units or are they the wrong lights???????
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Is it a Sportback or 3 door? Either way the light should be flush with bodywork. If its a Sportback, check the two locating lugs at the front of the unit are pushed home into the rubber grommets...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,083
    If it's a 3 door, it could be that some of the rear bulbs have had to be replaced and whoever has done the job hasn't refitted the lights properly. Best thing would be to remove them - very easy job - and try and fit them perfectly flush, so no more water gets in. xx
    andyam likes this.
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Mar 2010
    Hitchin, Herts
    138
    I have recently had a new LED cluster set fitted to my Sportback and have noticed a very small amount of water build up around the bottom of the lights, but as far as I know this isn't going into the boot.
    plezz's Avatar
    Aug 2011
    Romford
    233
    might be worth putting some pics up too in case it helps - might give people on here a better idea what the prob is caused by.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    as above stick a few pics up
    cant really advise without seeing the problem
    has it been this way sinse buying the car ?
    could be simple refit or a bad repair
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    Lugs may have snapped off
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    plezz's Avatar
    Aug 2011
    Romford
    233
    are they OEM? could be oddly shaped aftermarkets.
    26,723
    Yes as said, before we can advise, ideally need pics of them fitted & the rear of the lenses so we can ascertain if anythings missed or out of spec.
    Feb 2012
    dorset
    7
    i will try and put pictures up. I have had the o/s rear light off and it seems to go back on ok but still a quite large gap between body work and light, i have noticed the boot lid isn't quite flush with the lights either, i checked to see if it was an insurance write off, stolen or scrapped but it came back clean, it does look like a repair ov somesort has been done but not very well and the paint job isn't the best either
    bez101's Avatar
    Jul 2008
    7,926
    cant really advise untill we see the pics
    it may have been damaged and not claimed on insurance
    Feb 2012
    dorset
    7
    how do you get pictures up?, i've taken some and sent them to facebook but cant seem to get things to work right, sorry but not a techno geek
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    When I bought my car a few months ago one of the rear lights had a small gap between the bodywork and housing. I just tightened up the hexagonal screw, behind the light in the boot. This pulled it back into place.
    Try that, if not I would try taking it off completey so you can see how it all fits to the car and see if anythig is stuck there or bent. There is not much that can go wrong back there, just 2 points that pop into place and the screw in the back. (Thats what she said).
    Some photos and advice on removing on some other forum:
    Rear Lights - Removal, how the hell?? - uk-audis
    Advice on uploading photos
    How To: Post pictures on the forum.
    ....................I'll make a build thread one day.
    Feb 2012
    dorset
    7
    Last edited by Mick Rowley; 20th March 2012 at 20:29. Reason: its the only way i can get pictures or links to pictures on the thread
    bez101's Avatar
    Jul 2008
    7,926
    make it bigger
    Jan 2012
    SW London
    751
    make it bigger
    Thats what she said....
    sachen likes this.
    26,723
    Not the best pics tbh but alas, need to ee the boot lines from the rear not the side to see the degree of bad fitment & distance pics, not nose to the lense.
    TBH it doesnt look as bad as you make it to be.
    But, check the rubber grommets on the side of the car, that the rear light ball joints push into, havnt pushed into the cavity of the chassis, common to happen when not being careful or fitting properly.
    You can also stick some say fabric cloths strips (coroplast) onto the paintwork, build it up behind the lights so it stops it from rocking/piveting against the car as such & then also pushes it out a bit, at the bottom below the main hole where it bolts on with the plastic nut.
    bez101's Avatar
    Jul 2008
    7,926
    prob had a smack and crap repair
    Feb 2012
    dorset
    7
    thats what i'm starting to think, but no record of any accident involvement, thanks for the help its been very helpful
  1. Rear light clusters
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:54
  2. Rear light clusters
    By A6UYC in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th January 2010, 17:37
  3. Rear light clusters
    By mrmule in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2009, 23:40
  4. What Rear Light clusters?
    By Trickey Dickey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2007, 12:51
  5. LED Rear Light Clusters
    By haywood in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2005, 18:18
