EM TuningBadger5
Results 1 to 7 of 7
    Mar 2012
    remap and lowing 2.0 tdi 170
    Hi,
    I have a audi a3 2.0 tdi 170bhp s line 56reg with the dsg gear box and i can get it remap to 204bhp also thinking about getting PI lowing springs at 45mm.
    Would i have any problems in the long run?
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    If it's a quality remap, then you won't have a problem. I used PI springs a long time ago and they seemed to corrode quite quickly. Not sure if they have improved since then. My personal recommendation would be Cobra and Eibach.
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Mar 2012
    Thankyou,
    I've had them on for about 15 months and seen to be fine.
    I have done both to my previous car (BMW mini) but didn't no if there was any commen faults in the progress.
    v1raj's Avatar
    Apr 2009
    279
    Quote Originally Posted by D COOPER View Post
    Hi,
    I had mine lowered with H&R 50mm springs and the result was better than the standard S-Line setup.
    Also, Trups at www.EMTuning.co.uk carried out the DPF delete and remap on my A3. Although i havent had it RR'd, i was advised the map would be around the 210-215hp mark.
    Would definitely recommend him.
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
    Dec 2011
    MIDLANDS
    241
    I 07 s line 140, had it remapped by Awesome GTI and fitted FK coilovers. The ride is surprisingly good as it is wound down low, and would not look back after the remap. If you drive it steady you get an extra 5-10mpg but the power is there if you need it.
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    Mar 2012
    A, A
    Ive had de-dpf and Custom code remap last year. Totally changed the car. 2.0 TDI 170 now running around 230-240 bhp and 340 lbft. Not so good on front tyres but puts most rice rockets to shame! If you ever have problems with DPF I would highley advise this mod.
    APAutomotive's Avatar
    Shark Performance Shropshire
    Mar 2012
    Telford, Shropshire
    81
    eibach springs are good for the money, & ride quality is not too disimilar to OE springs. I also recommend H&R if you have a little more to spend.
  1. Chip or remap Audi a3 tdi 170 quattro(help)
    By Barny907 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2011, 12:08
  2. ? realistic remap gains 170 tdi
    By Macdoon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th July 2011, 22:08
  3. Audi a3 8p tdi 170 quattro Remap
    By ckman85 in forum Sales Questions
    Last Post: 27th June 2011, 12:18
  4. 170 tdi remap
    By b19ctr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2011, 01:46
  5. 2.0 TDi 170 Quattro Remap.. Bluefin?
    By elgan in forum Diesel forum
    Last Post: 10th December 2008, 21:36
