AH FabricationsVolks Autos
Results 1 to 13 of 13
    Feb 2012
    Northumberland
    88
    Audi Concert to Audi Symphony II+
    hi all
    i've got S3 09 with Audi Concert headunit (Double Pin) and I want Audi Symphony II+. anyone know if its a straight swap? or will it need a different adapter at the back?
    many thanks
    a3_sline_tdi's Avatar
    Aug 2009
    898
    This is straight swap afaik
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Feb 2012
    Northumberland
    88
    ok, the guy has got the code for Symphony II+ unit. do I need to put in code or does it need to go to the Audi for that? not sure it works with the code thing
    Dec 2011
    York
    93
    Aslong as he has the correct code, install into your vehicle and enter code and your sorted
    Apr 2009
    Florida (previously Liverpool)
    655
    You may need VAG-COM to code for options such as multi-function steering wheel, Satellite radio, Bluetooth, Aux-in, CDchanger/Ipod dock or whatever other goodies you have.
    Feb 2012
    Northumberland
    88
    thanks for the info VVAddict.
    26,747
    As long as its a concert 2+ then its the same yes, but as Keith states, it will probably need coding for any options you may have in the car.
    Feb 2012
    Northumberland
    88
    how can you tell if its a concert II+? my car is Mar 2009 8P3 (facelift)
    My previous A3 was built in April 2009 and that had the Concert II.
    Dave R (h5djr)
    26,747
    It should be fine with that age of car.
    Apr 2009
    655
    Concert 2+ was always labeled Concert 2 (without a '+'). This is confusing because that's also how the concert 2 was labeled...
    But -in simple terms, 2008 or later should have the concert 2+ -No cassette deck, and a large screen... Quadlock connector on the back. Basically of the front panel layout is largely the same (with the only real difference I can think of being around the eject button on the CD slot) then it should be a straight swap.
    -If the car it's coming from had the same options (steering wheel, satellite/digital radio, iPod dock etc) then you might not need any coding, but the unit will BASICALLY work either way (once the security code is entered!). -The only things which would be messed up would be stuff like the steering wheel controls not working, if it's not coded for MFSW and your car has one, or the digital radio not working if it's not coded for digital radio and your car has it... you know, that sort of thing.
    But other than that, if the front panel layout is basically the same, then you have a 2+ (not sure if they were still using the older radios in the UK, but in the USA then any non-navigation cars were ALL concert 2+ or Symphony 2+ from 2008 onwards) then it's plug and play. Options will function depending on coding, at which point you should either give some beer to a local VCDS owner, or contact NHN about discovering the jo of VCDS ownership for yourself... -Trust me, it's worth it!
    Feb 2012
    Northumberland
    88
    right just found out my concert plays mp3! need more help.
    i've got a Phatnoise from my VW Polo brought a cable on ebay to fit to back of the headunit for the Audi but don't seem to work unless i need to find a better earth connection. where is the best place to put it earth cable. so do i need to code this in?
    i have photos but not sure how to stick on the forums. photos of the quadlock and cables fromthe car.
    Feb 2012
    Northumberland
    88
    earth cable here, but does it need to be metal to metal?
    this is the cable for Phatnoise. white connecton is to go to headunit
  1. Swapping Audi Concert for Symphony or Multimedia
    By V8Guzzler in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2011, 15:24
  2. Audi Concert, Symphony, RNS-E etc?
    By Ben H in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2010, 11:51
  3. Audi b6 2003 concert to symphony 2 upgrade
    By steveboyo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2010, 17:59
  4. Audi Symphony V Concert V Chorus
    By jonboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2007, 17:53
  5. Upgrade from Audi Concert to Symphony 2 ?
    By NeilC in forum Classic Audi Forum
    Last Post: 9th April 2005, 18:43
