Chris NottSky Insurance
Results 1 to 9 of 9
Thread: Sat Nav PIN
    Mar 2010
    Hitchin, Herts
    138
    Sat Nav PIN
    I don't seem to be able to find the PIN number for my Sat Nav unit. I thought it was with all the documents supplied with the car when I bought it from the previous owner as it was a factory fitted option.
    I'm going to need it when I change my car battery!
    Is my only option to visit Audi or is there another way of getting the code before I disconnect the battery.
    Chris
    Sportback owner
    Apr 2007
    France
    465
    Chris, try looking in the Sat Nav user instruction manual. In mine, it was after the front cover, printed on a small tear-off portion. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Mar 2010
    Hitchin, Herts
    138
    Quote Originally Posted by Geraldy212 View Post
    Unfortunately I've checked that. Mine just has an empty space where the PIN number should be!!
    Kicking myself for not checking Properly when I bought the car!
    Fossie
    Rhubarb Triangle
    3,961
    If it was factory fitted, as far as I'm aware, you shouldn't need the pin code as the unit recognises the last car it was installed in.
    Same with Concert and Symphony units.
    26,758
    As Mike states, Audi for a while now havnt included the pin code inside the book anymore, because it remembers the last vin no. so you so you should be fine.
    Mar 2010
    Hitchin, Herts
    138
    Sounds like I might be okay disconnecting the battery then and that would also explain the lack of a PIN number in the book.
    Looks like I should be safe changing the battery for a new one then although the manual does state that it will require a code if the battery is disconnected so I'm slightly nervous about this! I assume Audi can get the code easy enough if it did decide to go into SAFE mode?
    26,758
    If you're that worried, stick some booster pack clamps on the terminals before disconnecting battery, to maintain the 12v momentarily & then swap battery over, reconnect the termianls & then remove the clamps, personally I think you'll be fine, also audi can get the pin no. fairly easily yes, albeit probably at a price.
    Mar 2010
    Hitchin, Herts
    138
    I did consider that option, but I only own a trickle charger so not sure that would work in the same way?
    It sounds like I don't need to worry.......well not about my PIN code anyway! I'm sure I will think of something else to worry about soon! Lol
    Fossie
    Rhubarb Triangle
    3,961
    Trickle charger will be fine - it's only keeping the memory active.
    Stop worrying mate, you won't need the pin if it's definitely factory fit !
  1. RNS-E Upgrade from 2009 Sat Nav disc to 2011 Sat Nav disc
    By pluves1 in forum Satellite Navigation
    Last Post: 23rd June 2011, 19:19
  2. upgrade sat nav sat nav cd????
    By CHRISS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2007, 14:34
  3. S3 - retrofitting Sat Nav Plus to Sat Nav system
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2007, 11:33
  4. D.I.S Sat Nav as opposed to DVD + Sat Nav?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2005, 00:43
  5. putting in sat nav (any1 with sat nav already)
    By pteyeo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2004, 16:30
