Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Feb 2012
    17
    RNSE again sorry
    Hi ive taken my symthony 2 out to install a rnse mk2 but have realised i need the plug adaptor there is a lead with a yellow plug on the end will this fit into the new adaptor block ? ive searched but with no avail ay help cheers
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    Hi Matty, welcome to ASN. What car do you have and what year is it? Someone should be along soon to advise you. Enjoy the forum?
    Feb 2012
    17
    Hi its a 2005 a3 tdi quattro ..it has bose installed too but dont wanna purchanse the adaptor block if its the wrong one just unsure what the yellow block is for
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,397
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    If you take a photo bud that should help...
    Mine was plug and play apart from the Bose pin. Not done a 2005 A3 myself.
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi Bluetooth -AMI/iPod - RNSE Navigation Units - Cruise Control - Optical Parking Systems - DAB (Digital Radio)- Audi Factory Retrofits- Stolen Vehicle Tracking - In-Car Cameras- Genuine VCDS Cables
    Feb 2012
    17
    Symphony II RNS-E sat nav Retrofit
    Its the 3rd picture down mine is like this but do not no were it goes any help cheers
    Feb 2012
    17
    Rob_'s Avatar
    White Audi A3 S-Line 09
    Mar 2012
    Nantwich, Cheshire
    6
    Hi Matty, I recently retro fitted a RNS-E unit to my A3 S-Line 2009. That 'yellow' connector is the diversity connection. Although I did not have this in mine in the same set up as you (because I had the Audi Concert head unit) I am able to help you out somewhat.
    Using a small thin flathead screwdriver, or something similar, pry out the purple plastic lock from the yellow diversity connection.
    Once the purple lock has been removed, the yellow plastic cover will slide right off. Remove it.
    The kit you will need to order should included the Radio Antenna Adapter. This cable is needed in order to connect the FM antennae to the back of the RNS-E unit. I should look like the following: (found this pic on the internet btw)
    Once you have removed the yellow plastic cover from the connector, it should clip onto the "Symphony-ZF Diversity ant." - as it is labelled on the picture above. I recommend using some electrical tape or something similar to hold it in place securely.
    In case you are wondering what a diversity antennae is, it is also known as space diversity, is any one of several wireless diversity schemes that uses two or more antennas to improve the quality and reliability of a wireless link - in this case, your radio!
    I hope this is of some use to you?
    Good luck with the install, let me know if I can help any further!
    Feb 2012
    17
    any help guys cheers
    jasonc's Avatar
    Jun 2011
    Reading
    134
    I've never worked on a 2005 but I'm pretty sure that the yellow plug is the diversity antenna connector. You should have 2 antenna connectors - a round one and a square one.
    On the RNS-E both antenna connections are on the same plug so you will need an adapter cable to go from the 2 connectors you have to the single connector for the RNS-E.
    If you look at the 4th picture on the thread that you linked to I think that the silver connector in the middle is just the yellow connector with the plastic cover removed.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Hi mate, I assume you got the quadlock adapter.
    The lead with the yellow plug is one of the antenna leads, you need a diversity adapter so you can convert the two antenna leads to one. You will have to take of the yellow housing when you use the adapter.
    Here is a link to the quadlock and diversity adapters needed.
    http://item.mobileweb.ebay.co.uk/vie...id=59587041205
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Feb 2012
    17
    oh thats great guys cheers il av a pop at it this week let you know ..really appreciate it
  1. help with rnse
    By the jammy one in forum Satellite Navigation
    Last Post: 18th December 2010, 10:08
  2. Where to get a rnse
    By tku in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2010, 17:33
  3. anyone want RNSE ?
    By davidkoulakis in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th July 2010, 09:04
  4. anyone want RNSE ?
    By davidkoulakis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2010, 01:37
  5. rnse help!
    By luke32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2007, 17:51
