EM TuningMonster Motorsport
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By paddy
Thread: Talk to me about the Revo SPS switch...
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,340
    Hi guys,
    Now I've gone to Revo Stage 2+ I want to be able to change the settings to ensure the car is running at its best whatever the situation (increase in air temps etc). I'll be doing this by doing some data logging on VCDS to see how the settings affect timing pull ect.
    So can I just buy a switch and plug into laptop/car and away I go, or does the switch need matching to the car /map by a Revo dealer?
    Can the switch change settings without the laptop, ie when your out and about?
    Which verison of the switch do I need?
    Finally, has anyone got one for sale?
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Buy a switch and plug it into car and you can download trhe car settings to the switch then plug into a computer and read settings and alter to suit. Plug back into car and upload the new settings. Basically you get a 1-10 option on Fuel/boost/Ignition advance Timing. You can also plug in to car and immobilise if you want to leave the car in a carpark at the airport for example for a couple of weeks. You have 3 custom sets of settings you can pre load into the SPS and upload to car so you can drive to the track on setting 1 change to setting 2 for a track day and reset for drive home. Takes about 20 seconds to change the setting on the car via the switch.
    Once you have put your settings into the SPS you dont need the laptop with you to change the car settings. Just select setting via a multi option switch on SPS, plug into car for about 20 seconds untill unit beeps then unplug...all done.
    HTH
    Silky-S3's Avatar
    Jan 2009
    1,340
    Quote Originally Posted by paddy View Post
    Cheers Paddy. Have you found much difference between each of the setting? Ie from 0 to 9 boost, big difference? Ever set it up on the car and had it pull back or go into limp mode?
    Build Thread Here!
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,458
    Hi silky sps switch lets u change settings for boost, timing ,and Fuelling via switch or via computer to do any logging you would need to buy a ross tech cable ..
    Ross-Tech Store: VCDS License with HEX-USB+CAN Interface
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    The fuel setting is basically just an adjustment for octane 95-99-100+. The advance setting worked well for me as it smoothed the stock setting out nicely and gave better throttle response. The boost setting is default 6 so i have not tried that as it runs really well as it is and i dont want to over boost the lump on the road. Warren has tried various boost settings so maybe try him ? I went from timing 5 to timing 7, very noticeable.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I would add i have had my custom setting set in the car for 6k miles now and its never missed a beat.
    Silky-S3's Avatar
    Jan 2009
    1,340
    Ok, thanks for the great info.
    Build Thread Here!
    Silky-S3's Avatar
    Jan 2009
    1,340
    Quote Originally Posted by s3kel View Post
    Cheers mate, already got a VCDS cable Thanks anyway.
    Build Thread Here!
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,458
    Hi paddy what settings you using
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    I have settled on 6 Boost/9 fuel ( if you stick to 99 octaine)/ and 7 timing. seems to work well
    Warren has tried other setting inc higher boost so maybe try him for more info.
    Kelza likes this.
    Silky-S3's Avatar
    Jan 2009
    1,340
    Cheers guys, got one on its way. Looking forward to having a play!
    Build Thread Here!
    Silky-S3's Avatar
    Jan 2009
    1,340
    So, got my switch today. Just checked what I'm on and its
    Boost: 9
    Timing: 6
    Fuel: 9
    These seem pretty aggressive? I'll hopefully do some logging this weekend and see whats what. I take it a lower setting say on boost may yield more performance if 9 is too aggressive and the ECU is pulling back? I would be feeling that though?
    Build Thread Here!
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,458
    Wow , hi silky best to run vpower on fuelling 9 , i will get my setting just now , set up by steve jnr at statllers...
    Silky-S3's Avatar
    Jan 2009
    1,340
    Yep, always on V-Power
    Build Thread Here!
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,458
    Cool lol,,settings a 7,6,6 .. B 8,7,6 .. C 9, 6, 8 ...
    warren_S3's Avatar
    Oct 2007
    6,067
    9/6/9 does seem a bit optimistic.
    I'd be inclined to run something more along the lines of B7/T6/F6 as all that boost is going to put the inlet temps up quite high which will in turn cause quite a bit of timing pull. Do you feel the car gets lazy as it gets hot?
    If you have a more efficient intercooler it might not be such an issue, but I'd certainly log the car.
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    Silky-S3's Avatar
    Jan 2009
    1,340
    Cheers guys, will log this weekend. Haven't felt it get lazy, just pulls like crazy all the time. I thought fuel should be left on 9 according to this? http://www.revotechnik.com/resources...uide_V0707.pdf Page 19?
    Build Thread Here!
    Silky-S3's Avatar
    Jan 2009
    1,340
    Just got this from Kev at Revo
    "Baseline settings for your vehicle would be boost-7 fuel-6 timing-4. if your original settings are what the dealer put in, then im guessing that setup is perfect for your vehicle. As for the fueling 1 is rich and 9 is lean."
    Logging this weekend. Been running B7, T6, F6 for the past few days to stay safe and its much flatter...
    Build Thread Here!
    Mar 2010
    16
    I would be interested what you ended up using.
  1. REVO SPS switch used once!
    By gynads in forum For Sale/Wanted - Audi Parts
    Last Post: 16th February 2012, 09:12
  2. revo sps switch
    By R1KVX in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2011, 17:15
  3. Revo SPS 3 switch - What's it worth
    By glen_jai in forum General Automotive Chat
    Last Post: 15th September 2010, 17:50
  4. Revo Booked! But which sps switch?
    By s3 Hoggy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2009, 22:25
  5. SPS Revo Switch - Diesel Remap
    By Boydie in forum Tuning
    Last Post: 27th December 2006, 13:59
