AH FabricationsEM Tuning
Results 1 to 7 of 7
    Sep 2011
    Harlow, Essex, United Kingdom
    22
    HELP engine light on
    Hey guys n girls last couple of day iv had a engine light on iv plugged it up and got these codes
    01026 = rear evaporator fan (v20)
    00257 = ABS inlet valve: front left (N101)
    iv google the codes but not found anything can anyone help im able to reset the light but ends up coming back on the following day
    cheers for your time adam
    Jan 2012
    17
    what car is it
    Jan 2012
    17
    if its a a3/ mk5 golf abs pumps are a problem with them vw do a repair kit done 7 of them naw
    Sep 2011
    22
    Quote Originally Posted by gazb8 View Post
    what car is it
    it a a3 8p 2.0tdi 2007 140
    the car seems fine to drive and performs still under heavy breaking just not sure where to start
    Sep 2011
    22
    can anyone help
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    mine has come up with brake pressure switch
    ​She is back on the road yay!!
    27,126
    Thats not good.
  1. Guide: ESP Light On- Glow-Plug/Engine Light Flashing - Cause & Fix Inside!
    By Yoof in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2014, 09:21
  2. Coil Light Flashing & Engine Management Light
    By vik007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2012, 19:43
  3. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  4. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  5. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
