JMB RetrofitsChris Nott
Results 1 to 25 of 25
Thread: Handling....
    ilim's Avatar
    Nov 2011
    632
    Handling....
    As the s3 hasnt got the best handling.. planning to get coil-overs and FARB and RARB.. would these 2 together give better handling?
    ilim
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    The short answer is yes.
    The best of the mainstream coil overs are kW or Bilstein and again with each there are options in terms of price and adjustability.
    ARBs will improve the handling and together with good coil overs will reduce understeer and soggy handling.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Is there anyway of retaining the original shocks (for the comfort) & fitting the F&R ARB.
    I had lowered kit on the TDI & the ride was awful even on 18,s. I dont want that again on the S3.
    I understand there has to be a compromise somewhere, but i suspect even the addition of ARB,s will improve it no end
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    You certainly can fit just uprated ARBs but that's not going to completely cure the problems.
    Maybe the best way is to simply fit the ARBs and see if that's sufficient before going to the cost of coil overs as well.
    A decent set of coilovers such as the kW v3s will offer a good ride as well as much better handling but do need a bit if time tailoring the bump and rebound settings to your requirements.
    Mine is pretty stiffly set up but still rides bumps etc well without bashing your fillings out.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    If you don't want to lower the car but want to improve handling then uprated ARBs are a good way to go.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Cheers for that. I admit the TDI only had springs fitted with genuine shocks so that will account for the ride. The KW3 seem like a fantastic set of shocks.
    I can only imagine it then gets into an "OCD" type of effect where i cant leave them alone & will be constantly meddling & never happy.
    Whats the concensus on the KW2 ?
    My S3 nearly went across 2 lanes on the slip road last night when i hammered it
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    The v2 would be a decent comprise if you don't want to spend much time setting it up.
    If you want something you can either fiddle with or change as you alter other parts of the car then the v3 would be better.
    I'd have to say that it took quite a bit of time to get it right on mine and I do tend to be a bit obsessive about it.
    Now that the power has increased a lot more it's beginning to feel a bit squirmy again,so I can feel some more mods coming on.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    See, now i knew you were going to say you meddled with it ..A LOT...
    Quote Originally Posted by S3Alex View Post
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Quote Originally Posted by Blackie View Post
    Well yes....but it's now handling as I like it even if it's beginning to get overtaken by power again.
    Mine's not really the best example to go from as it's been modified beyond what most will stop at,but at Stg2+ that setup really does work well.
    I need a bit more front end on mine plus a few other ideas but it does have around 500bhp to manage.
    Getting back onto the summer tyres will help me but in your case,you may find the v2 is better.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Morells
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    I've got the H&R ARBs on mine but I don't know what the suspension kits you've mentioned would be like.
    You need to decide really how much you want to do to the car,as you need decent suspension and brakes for Stg2+ but would be OK with lower priced solutions if you stay with less power.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I am only planning on staying @ St1 . I have just ordered some H&R ARB,s & an anti dive kit. I,ll fit those & see what happens
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    I'd have thought that should work well and will save you shelling out for a suspension kit which you may not need,or worse,paying for a kit which isn't up to the job later on.
    Hope it works out fine.
    PS....I thought Stg 1 would be enough until the old modifying bug bit.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    As they say "Power is nothing without control"
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Very true.
    You can get a lot more out of a lower powered car with good handling and brakes,than an overpowered brute that can't stop or go around corners.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Its often the mods that go unseen that are the best..
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    The H&R Cup kit is a very good option.
    Give me a shout if you need any prices.
    DPM Performance
    T: 01207 561606
    GNJ_Motorsport's Avatar
    Jun 2011
    Lancashire, England
    645
    If you don't think you would adjust the damping then KW V2 or V3 would be overkill. I'd go for something like the AP or Weitec Hicon GT coilovers and the H&R ARB's.
    AP Coilover Suspension Kit S3 8P / S3 8P Sportback 2.0T FSi Quattro (01/07-) - GNJ Motorsport
    H&R 24mm Front & 26mm Rear Anti Roll Bar Kit S3 8P / S3 8P Sportback 2.0T FSi Quattro (11/06-) - GNJ Motorsport
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Quote Originally Posted by GNJ_Motorsport View Post
    I gave exactly that sort of advice above and suggested he starts with the ARBs first and sees if that alone provides what he's after before proceeding further.
    It may be that a bit more roll stiffness does the job although that retains the coilovers as the next step.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    arbs are way to go. i did them first with whiteline walk kit and was really impressed with oem suspension. then i added kw v3's and...do i have to say more :D
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Jun 2011
    Lancashire, England
    645
    Yes spot on mate. I have H&R springs on our S3 at the moment as a stop gap until we fit coilovers and I find it still handles pretty well at Shark stage 3. In the summer I will be going down the coilover route with the H&R ARB's.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    I had the ARBs and kW v3 suspension fitted as one job,and it did make a big difference.
    What really rounded it off was fitting the Haldex controller,and together whilst they don't get rid of the understeer completely,it does remove most of it.
    The only way of correcting it fully would be adjustable top mounts and probably stiffer front springs and increased damping to match,but the top mounts will probably remove a lot of the road-friendly nature that it still has.
    I've had a road going race car before,and didn't really want to go down that route again.
    It is getting a bit squirmy again now,as I said before,as the power and torque have gone up a lot since the last round of mods,but going back to the summer tyres may help.
    Cheese's Avatar
    Mar 2011
    Surrey
    180
    Starting with just the ARBs is a good and lost cost option. I had Stage 2 and ARBs done in the same go and handling improved a lot with only a slight affect to the comfort. I got coilovers earlier this week and can absolutely fly round corners now but the ride is a lot firmer, which doesn't cause me a problem. But it is noticeably firmer. I haven't had any passengers since the mod but it will be interesting to see what they think.
    Audi S3 8P3 | Milltek TBE | AmD Stage2 | H&R ARBs | Bilstein B14 Coilovers | Sachs Racing Clutch
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Which ones did you get Cheese ?
    Has anyone uprated the bushes as well or is this not really an effective option ?
  1. A3 Handling !!
    By tommer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2009, 18:40
  2. Handling
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2009, 12:55
  3. Handling of and S3
    By DaveMK^ in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2008, 13:27
  4. S3 Handling
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2005, 21:59
  5. S4 Handling
    By welshdragon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th July 2005, 19:00
