Volks AutosAH Fabrications
    Apr 2011
    Oslo, Norway
    DIS retrofit - washer bottle sensor
    Hi.
    I have just retrofitted a new cluster with DIS in my '05 A3 8P,
    and was wondering if someone know witch pin goes to the washer bottle sensor I'm about to retrofit.
    It's definetly not pin 1 (I've tried that one), which is the only one I can find in other threads.
    27,096
    Pin 20.
    Apr 2011
    Oslo, Norway
    Thank you.
    Do you also have the pins for the radio controlled clock? Is it 9 and 10?
    27,096
    Yes.
  1. washer bottle leak
    By Ratzer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th April 2012, 21:44
  2. Washer bottle sensor
    By vroomtshh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2012, 20:55
  3. washer bottle sensor wiring???
    By paulsb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2011, 13:15
  4. Washer bottle filter?
    By One Spoke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2010, 12:22
  5. Washer Bottle
    By simonwjones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th January 2009, 00:37
