Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Feb 2012
    J519 Electronic Control Module
    Hi,
    Audi A3 2.0 TDI Sport 04,
    Recently got a J519 module fitted due to front windscreen wipers stopped working, since fitting some interior lights have stopped working including: lights on door handle, lights in compartment under radio and ambient light which shines down from roof, plus all button lights for radio, heaters and elec windows all flash continuously, not sure is this coding issues or what?, any help or advice would be much appreciated.
    cheers.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,318
    Hi, welcome to ASN. Where abouts do you live? Its possible you may need your car scanned with vcds. Sure one of the guys will be along shortly. Enjoy the forum.
    Aug 2010
    1,540
    sounds very much like a coding issue. who fitted and coded it?
    26,722
    What was the old CE board part number & whats the new CE board part no.
    Its not always as simple as plugnplay as there are various versions, coding plays a part yes, but so does the wiring, massively sometimes aswell.
    Feb 2012
    j519
    Thanks for replying,
    new part no:8P0907279P
    old part no: 8P0907279A
    Is it possible that at the point when the new module was coded in that if the light/dimmer switch plug wasn't connected properly this could have caused a fault? if not is there any way of restoring back to be recoded? to try again.
    26,722
    Well for a start you have a low line board & they've installed a high line board.
    Feb 2012
    what's your suggestions?
    what is the difference between the two boards?
    26,722
    Wiring differences potentially & coding.
    Mar 2009
    120
    Have you seen my thread? Central Electronic Module - Coding
    I had the same issues and sorted them eventually... You can start from default coding (it's in there) and modify one by one to see what changed.
    26,722
    Yeap you were my next call tbh
  1. Central Electronic Module - Coding
    By drsilviuro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2013, 16:13
  2. Electronic stability control help
    By Devious25 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd January 2012, 13:57
  3. Audi A3 AP J519 - Central Electric (CAN Module 09)
    By KieranFoot in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2010, 19:09
  4. Fitting the ABS electronic control unit....
    By au705557 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th March 2009, 16:29
  5. Traction Control, Mechanical Vs Electronic
    By Punisher in forum Tuning
    Last Post: 27th February 2005, 11:32
