AH FabricationsChris Nott
Results 1 to 30 of 30
Like Tree2Likes
  • 2 Post By NHN
Thread: S Line DSG To S3 Gear Knob Conversion !
    Feb 2012
    Essex
    16
    Question S Line DSG To S3 Gear Knob Conversion !
    Hi Guys,
    I have ordered the new DSG S3 gear knob for my Audi S Line DSG to complete my S3 convesion ! I know how to do it as it consists of heat and twist approach but this could be very costly and honestly i dont trust myself to do it.
    So i wanted to know if anyone knew a proffesional who could do the job for me properly i have the new gear knob it would just be a case of installing would be greatlful if someone could point me in the right direction
    27,108
    Well I'm not too far from you & as its my mod originally, guess I would be someone to do for you lol.
    N8 and ScottPalmer like this.
    Feb 2012
    Essex
    16
    Brilliant sounds good to me mate would you be able to install the s3 dial aswell ? where abouts you live and for how much for ? Its just i dont really wanna much it up as cant be without my car !
    27,108
    S3 dials, as in S3 cluster?
    Feb 2012
    Essex
    16
    Yeah the rev counter dial as it has a small S3 logo on it ?
    27,108
    So lets just clarify, you have a complete S3 cluster you need fitting or just the rev counter fascia part?
    Feb 2012
    Essex
    16
    Its just the fascia part mate ! eBay - The UK's Online Marketplace but will just be the rev counter part !
    Feb 2012
    Essex
    16
    Fancy doing it for me then mate ? Do you have an estimate to the cost of the change of the gear knob ? Cheers
    Sep 2009
    Trotters, Peckham
    539
    Quote Originally Posted by ScottPalmer View Post
    I assume you purchased the rev counter from Lockwood. That's an easy fix. Follow the DIY on ASN. Remember to not turn the key with the cluster detached.
    Word to the wise, twisting the pin is not the best way to do it IMHO.
    Cut the pin with a model saw
    Use a smooth nail file (finish) type and file a few times to each cut part
    Use a pin point and place a divet in the exact center of each cut end
    Drill with a 1 mm pin vise 3mm on the shift side and 2 mm on the tip side
    place a grub screw into the tip side and then attach the tip to the shifter side
    Done
    it takes 20 min and no eff up possible unless you have Parkinsons. No need for glue. Mine and others here have had ours hold up for over one year without any problems
    Any other specific questions may be addressed to tp.s3wannabe at vwvortex. he does all cars here in san francisco
    Feb 2012
    Essex
    16
    Thats brilliant instructions cheers mate but still i dont wanna have my car of the road would prefer it if someone like you with your expertise would do it for me i would obviously pay you for doing it sound good to you ?
    27,108
    I dont agree with that method tbh, you're basically cutting it in half which creates a weak point in the link as such, where as my original process retains the base structure & strength of the rod, each to there own of course, but for me the heat & twist with maybe some resin to make it a straight piece again is how I'd do it.
    Can swap the fascia over, assume you have a tfsi with matching rev counter numbering.
    Feb 2012
    Essex
    16
    I agree with you NHN you sound like you know what you are talking about ! Yeah the rev counter numbering is exactly the same ! Would you want to complete both of these cganges for me then ?
    - A3 S-Line DSG Gear Knob To S3
    - A3 Rev Counter Fascia To S3 Fascia
    I have all the parts would just be a case of you completing the labour work ?
    Wanna do it for me
    27,108
    I should do mate, its my mod copied around the world lmfao.
    PM me & we can get something sorted yes.
    Aug 2003
    292
    I was nervous doing the heat and twist method but I followed Nigel's instructions and it went really well
    only took about an hour and works perfectly now
    Sep 2009
    Trotters, Peckham
    539
    ^^^ that is for sure! That thread is infamous!! I can't remember but didn't someone snap off the tip after doing the mod with twist and heat only to use a screw to fix it?
    27,108
    LMFAO, I was pulling the climate out & fell backwards & snapped it of with my elbow, as the clips were stuck, but I repaired it with some resin, a pin etc as it was neccessary, buttttt did the heat twist to others & still recommend this if you have a non snapped rod :P
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Quote Originally Posted by tcardio View Post
    ....................I'll make a build thread one day.
    Sep 2009
    Trotters, Peckham
    539
    hehehehehe just a little nudge to the master. agreed!!
    Feb 2011
    535
    Whereabouts are you based Nigel? As this is a mod I would also like to pay someone else to do
    WANTED: S3 Side Skirts (3DR)
    A3 S Line DSG TDi 140 (56) | Lava Grey | Groove & Drilled Discs | Green Stuff Pads | Eibach Sportline Springs | Eibach Spacers | Full heated leather | RNS-E 2010 MK2 | Rear Parking Sensors | Interior Light Pack | Heated Mirrors
    loudchris53's Avatar
    Dec 2011
    Camberley, Surrey
    399
    likewise
    Chris
    A3 2.0 TFSI Sportback - DSG, Alcantara/Leather Heated Seats, Xenons, Acoustic park, Armrest, Folding/auto dimming mirrors, Symphony with Bose, Rain sensor, Multifuntion steering wheel, Lumbar Support, Aluminium roof rails, Lumbar Support, Vanity mirror lights
    MODS - ​RS3 Aluminium Race Inlay trim, LED rear lights, RNS-E, Bluetooth+SDS, Sline front bumper+Black grille
    27,108
    Based all over guys, so case of driving to you.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    Pics with the new knob?
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Aug 2003
    292
    Quote Originally Posted by Johnny Bravo View Post
    here's mine
    By tallpaultaylor at 2012-02-16
    before........
    Feb 2012
    Essex
    16
    Mod was complete today by NHN ! Came round and did a fantastic job looks brilliant and for people who say its a 20 minute job you have no chance if you want the job done properly ! Cheers NHN i am sure i will be doing other mods with you again soon ! Pics to follow
    27,108
    Scott was a pleasure meeting you today mate, always love this mod, transforms the use of said function completely & so much better to use as such than the side button version.
    Yeah realised today even more the slice & dice is definitely not the way to do it, cause if you misalign the rod by even a mm you may have difficulty in moving it round slightly, where as the heat & twist method allows adjustments without any such issues, also importantly allows you to test with the new stick before making permanent.
    I also now use a very good & iirc costly resin, instead of the epoxy, to strengthen the heated twist, I leave for a fair while to harden then dremel it the diameter to allow up/down movement freely, that way its as strong as can be
    I cant stress enough you really should do all your measurements before & after, like the height of rod in park position, the height of the bottom of the hole, also if the twist isnt exactly 90 degrees the gearknob can stick & thus wont allow key removal.
    GG
    Sep 2012
    24
    Quite fancy carrying out this mod to mine..... would need assistance though
  28. #27
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Quote Originally Posted by GG View Post
    Where are you based? I'd recommend NHN do it. Mine wasn't done by him & snapped the first time, new gear selector was £400, expensive mistake
  29. #28
    GG
    Sep 2012
    24
    Im based in North Yorks..... Any idea on cost?
  30. #29
    May 2012
    perth scotland
    421
    How much are the knobs from the dealers, I can't see any on eBay
    Audi a3 3.2 v6 sport back ,s-line, Dolphin Grey with factory tints, deg sat nav, bose speakers, 18 upgraded alloys, magnaflow exhaust, eibach pro kit springs
  31. #30
    27,108
    To fit, about £100, S3 ones are £91 from audi, I think I have an S3 one for sale.
  1. DSG gear knob swap?
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th January 2012, 17:58
  2. DSG Gear knob for 2006 A3
    By Agent_Trig in forum Parts Requests
    Last Post: 19th March 2011, 10:49
  3. Removing DSG gear knob
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2011, 17:37
  4. DSG Gear knob options on 2004.................. what do you have?
    By golfg6076 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 00:15
  5. DSG gear knob\lever replacement?
    By Wes G in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2008, 13:30
