Monster MotorsportEM Tuning
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Rear drivers seat belt is wet
    My rear drivers seat belt is wet its not really wet just damp but on looking at the rear quarter trim panel it's also wet at the bottom above the parcel shelf.
    1 is this the side the rear wash water pipe runs.
    2 how do you get the trim panels off so I can have a closer look at the problem.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    leach76's Avatar
    Feb 2009
    sheffield
    304
    Yeah thats the side it runs on mate had same issue with mine last week
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Cheers dude.
    I had a look at it and took off the main trim on the roof between the both rear quarters[IMG]
    then there was a star drive to unscrew on the rear quarter trim behind the roof trim (t20 I think)
    Then just started to pull the rear quarter trim which is held on by clips and it came down easy enough
    Then you can get into the rear wash pipe to reconnect it
    Mine was not fully disconnected just loose but when looking it came apart no problems. When putting it back together the 2 halves clicked together and it took a bit of force to securely clip then together.
    Hope this helps someone else.
    Fossie
    Rhubarb Triangle
    3,961
    Shariain - before you close up you need to tie-wrap the connectors together somehow or secure the connection some other way. Once they have split apart they do not work the same and will split apart again. Trust me !
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Cheers dude. I guess I will need to fix it again soon and will cable tie them together then as I have already closed up and it's now dark outside but I know to watch out for a weak rear water jet and will know that the pipes have came loose again and need fix again.
  1. rear seat belt
    By egesford in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2012, 00:07
  2. Rear Seat Belt Buckle
    By WaterBoy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2011, 20:57
  3. Drivers seat rear cover
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th May 2010, 12:37
  4. Rear seat belt mechanism
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2010, 13:43
  5. Stuck rear seat belt
    By chopper602 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th December 2008, 18:53
