Chris NottVolks Autos
Results 1 to 8 of 8
    Jan 2011
    54
    anti roll bar + anti lift kit on s3 8p
    fitting them 2, would it help me alot with steering? anyone can give me some feedback?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    I noticed a good difference when fitting my H&R ARB's - stiffened up the ride and cut out some understeer.
    The anti lift kit will give you better turn in and it isn't that expensive so you may as well - I will eventually get round to fitting the whiteline kit.
    warren_S5's Avatar
    Oct 2007
    7,163
    The A3 platform seems to suffer quite a bit of understeer and the more power you put through the wheels the worse it gets.
    I'm going to do the Whiteline kit (WALK) later this year, and if all is going well I may get rear ARB done at same time.
    Audi S5 3.0V6T Coupe Black Edition
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    ARBs make a lot of difference to steering behaviour. When I was originally researching for my 8L there were some very detailed threads about the ratio of the front and rear bars, and how each killed or worsened understeer. I think the jist of it was that the thicker the front bar is compared to the rear, the more understeer you get.
    Still don't really even know what he WALK is, or does (prevents the nose lifting?) so can't be much help on that one.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    warren_S5's Avatar
    Oct 2007
    7,163
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    got them both. excellent mod. did them first and few weeks later coilovers. when i fitted arb's and walk i was impressed with the handling and steering feedback. first i did set front arb soft and rear hard. it's a great combo, but then i tried hard front and back, and while there isn't any body roll seems that the understeer is back again. then had a play with wheels spacers, fitted them on the front axle, and now the handling is superb, no understeer no body roll :D
    i would say go for it. maybe just back arb and walk and you'll improve handling but it won't cost as much as complete kit.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    Both very worth while mods.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Oct 2003
    up north...
    767
    anti-lift is used on the tt/a3 to add front caster, which increases steering self-centre, and adds more negative camber on turns, which helps front end grip and therefore reduces understeer.
    widening the front track (relative to rear) and fitting a stiffer rear arb or stiffer rear springs also help to reduce understeer. if its an 8p then fitting the tt bottom alloy suspension arms at the front gives you more front negative camber, a wider track slightly and reduces unsprung weight.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
  1. S3 eibach anti roll bar kit
    By scotty_24 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2011, 09:07
  2. Anti Roll Bar Bush Kit - Info
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 09:46
  3. anti roll bar
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 11:06
  4. Anti roll bar kit
    By OnTheJazz in forum S2/RS2 Forum
    Last Post: 26th July 2007, 00:05
  5. Eibach anti roll bar kit
    By Randomjim in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th September 2006, 23:59
