Ths engine mounts or Vibra Technics Engine Mounts
Kelza
MODERATOR
Staff member
Cumbria
Hi i,m on stage 2+ on my s3 8p3 and have the ths mounts new sitting here but i,ve just seen the vibra technics mounts they look amazing , which ones are you using, or perfer... Cheers..
These vibratechnics are the ones i,m going for,,also is 2 lower mounts needed on the s3 8p3?
I've got the VWRacing mounts here which I believe are Vibratechnics.
Like these ones alex , also do i need 2 sets of lower mounts ,and what ones u using alex , race Or fast road mounts?
Hi boydie depends as some people dont bother , but while i get my clutch done i,m going put better mounts in ...
I had vibra on my TT and they were awesome, have had no experience of THS but can definitely say had no probs with vibra tech
Price for each brands lads? A worth while mod???
If I remember,the VWRacing ones were about £500 all in,so not cheap but very solid.
If you weren't going the whole Stg3/4 hog,the THS set are cheaper and effective.
For any Stg2+ or above engine I think you need one or other of these to deal with the engine flapping around on the standard mounts.
But....do be prepared for a lot more engine thrash.
Fast road mounts.....they're pretty hard but the race ones are solid.
You really won't want those.....my Escort had solid mounts and it's like being a passenger in a cement mixer.
have you considered these?
VF-Engineering and OE Engine Mounts for Volkswagen
On the lower "dogbone" mount, I suggest using HPA core interlock in combination with the VF mount. JUst in case you're wondering...vibration is minimal
Interesting.
The only thing that would concern me is the bit about them being tested with a 280bhp car.
The VWRACING/Vibratechnics mounts are very solid things.
Hi tcardio hpa core interlock with the vt lower monts like below...:)
Hi alex how you getting on with spec clutch ,, i may sell mine and go for a spec one ,so i,m ready for bt....
Hi mate yeah going get some vt mounts and hpa core mount ,just need to sell my brand new ths mounts first ,,thanks,,:)
In the middle of getting that together right now.
I really do like the look of the spec stage 3+ clutch , did you get the steel Or aluminum flywheel...
Steel...bit heavier and better for damping vibrations.
There was a problem with the first one they sent with tolerances on the splines so I'm waiting on a new one.
Right ,wow, looking forward to seeing your updates on your build thread , i,m just sorting out a vw racing bbk set up :)
Thanks.
I'll have some feedback on the clutch soon as the replacement part has arrived and will be going in shortly along with full boost.
694
S.
542
935
52
14K
13
7K
