Volks AutosMonster Motorsport
Results 1 to 17 of 17
    Oct 2011
    Teesside
    93
    Unhappy Coilover adjustment help please.
    Hi
    So as some of you may know I got my FK AK Street coilovers fitted on Saturday.
    The plan was to let them settle for a week then adjust accordingly.
    Problem is the rears have settled about 25mm and have (hopefully) stopped but is literally on its bum now - this is a major issue for me as there are several speed bumps and torn up roads ('improvement works') in my area at the moment.
    The husband - non mechanic was planning on being the one to adjust them for me until he realised the entire thread is inaccessible due to it being sat inside the bottom arm and it looks like the only way to adjust it is to remove the entire coilover - effectively starting all over again!!!
    Can anyone please suggest a way in which it can be adjusted without a refit everytime??
    My husband isn't a mechanic and really doesn't feel confident messing about with this and its gonna be a nightmare if I have to keep paying someone.
    Cheers guys
    tdi-man's Avatar
    Jul 2009
    1,611
    with my ap set just take wheel of unscrew little grub screw and turn the spring
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Oct 2011
    Teesside
    93
    Quote Originally Posted by tdi-man View Post
    He watched them getting fitted and helped where he could so i'll ask him if that rings a bell - he said theres just no way to get the 'c' spanner in to turn the adjuster coz of the way the bottom bar comes up at the sides all the way round - it's really stressing me out coz we go camping through the summer and I really wanted these to be fairly simply adjustable - I read on a random google search that someone fitted the spring upside down so the adjuster was at the top of the spring (not at the top of the suspension) but im not entirely sure that'd be safe!
    tdi-man's Avatar
    Jul 2009
    1,611
    dont need the spanner just turn the springs
    tdi-man's Avatar
    Jul 2009
    1,611
    oh is it the rears take wheel of stand on brake disc to remove spring takes to people adjust and refit its a bit of a *****
    Oct 2011
    Teesside
    93
    Right, thanks, I'll get him to have a go -
    this is how mine are but without that useful gap, is this how yours are?
    Oct 2011
    Teesside
    93
    Yeh its the rear - I'm really gutted about the difficulty actually - really seems to defeat the object of coilovers being adjustable and useful!!
    I just wish my bottom arm was like the one in the video - ridiculous that its not
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    mine are a bi**ch to adjust on the rear too , the adjusters are on the top of the spring on mine (are they onto of the spring on yours too) , to adjust them what i did was jack the car up remove wheel then get a trolley jack with a block of wood and put under the bottom arm jacking it up just a tad ( to take off the pressure of the shock ) then removed the one bottom - bolt drop the trolley jack down this will drop the rear arm too - then you can adjust the rear - to refit jack up the trolley jack again to meet the hole on the shock put bolt back in - drop jack down - refit wheel - drop car down easy as that
    ​She is back on the road yay!!
    Oct 2011
    Teesside
    93
    Quote Originally Posted by FranA3 View Post
    Hey Fran! Unfortunately my adjuster is on the bottom of the spring sitting 'in' the bottom arm 'cup' - totally inaccessable unless the bottom arm is moved away - once they have been adjusted so that the adjuster/locking bolt is flush with the sides of the bottom arm it'l be fine to access but at the moment when I'm in desperate need of adjustment its terrible - to make matters worse the access road to where I work has conveniently been DUG UP! today
    When they were fitting them, they did query this and wondered if it shouldnt be put in upside down for ease of adjustment but in the end they went with putting it the way the logo was written - seems like a massive design flaw.
    Also (please excuse my utter lack of terminology here) if we try to do it how you do yours, does that skinny bar need to come off aswell - the one that comes with the coilies - a strut I suppose? and does the top part of your coilie stay in situ.
    Thanks Fran
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    all the coilovers I've seen have the adjusters on the top of the spring thats weird lol , you can do it exactly the same way if its on the top or bottom as you're taking the pressure off the spring so its loose after you take the bottom bolt out , just do it the same way all will be ok , you might have to take the spring out to adjust it though but will still work
    Oct 2011
    Teesside
    93
    Mine are exactly like the one in the video (above) but without that gap in the bottom arm cup that that guys car has.
    Like I say they did wonder whether to put it in with the writing on the spring upside down but decided against it just incase.
    Would certainly be of assisstance if FK put a general how to guide in the box!
    Unfortunately, my bro-in-law who fit the coilies last weekend is working this weekend and on shifts all next week but thankfully an old school friend is a mechanic and hes offered to do them for me tomorrow night after work - how long do you reckon it'll take him to adjust them? - the fronts need to go down about 10mm and obviously the rears up about 20mm.
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    Quote Originally Posted by AllThatGlitters View Post
    haha yeah same as mine they didn't come with anything either lol , i wouldn't have thought it would take long at all , i fitted the whole of the rear in an hour when fitting them so shouldn't take long at all , i would say an hour tops
    Oct 2011
    Teesside
    93
    Oh god - my entire set took half a day - and by that I mean LITERALLY! We got home at 20 past midnight. In my bro-in-laws defence he had just come off a night shift and it was FREEEEEZING and he very thorough but after 8 hours I was over it - by 10 I didn't care anymore haha
    Oh well an hour for adjustment isn't too bad seeing as i'll be starving and ready for me tea - chippy me thinks! haha
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    i hate the FK cause ot that
    when mine needed doing i got the car on a 2 post lift and they were still hard work
    best way is to take spring out adjust and refit
    FranA3's Avatar
    events moderator
    Dec 2008
    south wales
    7,124
    the rears were easy as hell the fronts on the other hand were a mare to do they took me about 4 hours with air tools too haha , let us know how you get on
    Oct 2011
    Teesside
    93
    Totally defeats the object doesnt it! - Right carry on.
    Oct 2011
    Teesside
    93
    Yeh the rears seemed to go on ok but when he took the first front one out the original spring was snapped right at the top and they were a bugger to get out then the new ones were stubborn to get in. Felt really sorry for him he must have been as sick as a pig coz I was & it was for my car haha
    Yeh, i'll update tomorrow - hopefully it'll be before half 6 and not after half 11!
  1. handbrake adjustment
    By JR6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd October 2009, 05:18
  2. Replies: 6
    Last Post: 24th June 2009, 22:46
  3. handbrake adjustment
    By darcar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th March 2009, 12:28
  4. Clutch adjustment
    By rob1380 in forum General Technical / How To
    Last Post: 19th April 2007, 13:19
  5. adjustment
    By tommyt2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2007, 18:38
