Volks AutosBadger5
Page 1 of 3 123 LastLast
Results 1 to 40 of 103
    Feb 2012
    124
    New shape S line steering wheel on a 2003 audi a3
    i brought my a3 with the new shape s line steering wheel already fitted.
    the esp light and the airbag light is on and when i took it to the garage today and it got looked at on the diagnostics, it came up with errors with the slip ring and angle sensor i think, the garage has told me to buy a new airbag slip ring, will this fix the problem? i've heard that these wheels are almost impossible to fit because the new shape wheels have dual airbags, shoud i just get a new 2004 steering wheel and get rid of this one??
    any help would be appreciated
    Feb 2012
    124
    i've seen on the internet that recailbrating might make it work?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Your car has a single stage airbag, that steering wheel is from an 05 > with dual stage. It will not work 100% properly.
    Feb 2012
    124
    so if i get a 2004 wheel, this should get rid of the problems?
    Feb 2012
    124
    if i kept this wheel what would i need to do to get it to work properly and get rid of the errors?
    wez3570's Avatar
    Jan 2011
    711
    Quote Originally Posted by harris9053 View Post
    NHN has the knowledge!
    2006 A3 3.2 DSG
    Quattro S-Line
    Phantom black pearl
    V Maxx plus coilovers
    Speedlines- anthricite
    MY11 rear lights
    MK2 TT Vents
    Various LED's
    MK2 RNSE
    LaminX on fogs
    For Sale Genuine Audi phone cradle (iPhone 4S/4)
    Fossie
    Rhubarb Triangle
    3,969
    I think NHN will confirm that as your airbag control module is single stage then you cannot use a dual stage airbag and expect it to work.
    The control module also operates all the other airbags so it isn't just a case of changing the module.
    It has been known for people to alter the wiring of the airbag but I don't think Nige will recommend this !!!!!!!
    Feb 2011
    Aberdeen
    96
    Quote Originally Posted by N8 View Post
    What he said.
    Feb 2012
    124
    it seems like all the s3 replicas on ebay are 2003/2004 and have these fancy steering wheels on with no errors, i'm pretty sure if they crash, their pretty ****ed
    27,099
    Ok 1st before we condemn the wheel, although Mike & N8 are 100% correct the 03 car uses single stage airbag & that wheel is dual stage, but that seems a secondary issue as you are advising us of steering angle errors which has nothing to do with the airbags atall.
    So 1st need to ascertain the issue with steering sensor, do you have the logs?
    Feb 2012
    124
    if i replace my wheel with that will it be ok? is it a single stage? and is that the best looking wheel i can get thats single stage or is their a better wheel i should go for?AUDI A3 SPORT STEERING WHEEL 2005 WITH AIRBAG | eBay
    27,099
    Before you go out looking for a wheel, find out the actual errors 1st, as I said wheel is secondary atm if those errors you advise are there, fix the sensor & esp errors 1st then attack the airbag warning.
    Fossie
    Rhubarb Triangle
    3,969
    What Nige means by 'do you have the logs' is - have you had it scanned for faults with VCDS to ascertain the actual reason for the warning lights being on.
    Feb 2012
    124
    okay i've just rang the guy that did the diagnostics and he said it wasnt the angle sensor it was the driver side airbag ignitor circuit, the reason the wheel got changed is because the car had a bump and airbag went off on the old wheel, thats why the new wheel has been put on
    Fossie
    Rhubarb Triangle
    3,969
    OOOPs - then whoever did the repair either didn't know the difference or couldn't be arsed to get the proper wheel/airbag and the guy that sold it to you has sold you a car with a safety feature that will not work.
    Over to you Nige !! lol
    EDIT - are you sure there is actually an airbag in there ? It could just be the cover ! If the horn works you will have the airbag.
    27,099
    Yes but esp doesnt light up when the airbag system detects a fault, just lights the airbag light up on cluster, so can we be sure its esp & airbag light or just airbag light?
    Feb 2012
    124
    i need to get to the garage and write down exactly what codes come up or find some one with a vag com nearby
    Feb 2012
    124
    esp and air bag light is on
    Feb 2012
    124
    just went out side and tested the horn! it works
    Fossie
    Rhubarb Triangle
    3,969
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,033
    the horn is easy to wire up, is it posible you could take the airbag and check the wires?
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by amar06fbr View Post
    Do you mean without having an airbag ?
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    ooops, sorry, take the airbag off and check the wireing behind it.
    For Sale
    BBM: 28E07323
    Fossie
    Rhubarb Triangle
    3,969
    No probs mate - I think we may be at cross-purposes here.
    I said in post #15 at edit that if his horn worked then he would have an airbag. My comment was based on the premise that his steering wheel may just have included an airbag cover and not the bag itself, hence having the warning lights.
    When you said can you remove the airbag to check the wiring I was really asking you if it was possible to have the horn working with the actual airbag not being fitted (if you see what I mean ) !!!!!
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    ohh but it is possible to have the horn working with just the airbag cover
    For Sale
    BBM: 28E07323
    Fossie
    Rhubarb Triangle
    3,969
    Aha - I did not realise that mate - thanks for the info. Should be me headbashing ! lol
    It did seem strange that after a bump the repairer fitted a more modern wheel which required a more expensive airbag !
    Harris -you need to check whether you have an airbag at all mate.
  28. #27
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    my mate bought a A4 dammaged repaired, aibag light was on, horned worked but when he pressed the horn it was like the cover was going break in, i had a look and took the airbag cover off, it was screwed on to a piece of wood wich was screwed on the steering wheel and the airbag cover had 1cm wide hole with springs so it would bounce back. the wood had one of the horn wire stuck on it and ther other stuck on the airbag cover and the horn worked , the tings some ppl do to save a few quid.
    For Sale
    BBM: 28E07323
  29. #28
    Feb 2012
    124
    you've got me worried now! lol ...how do a dismentle the steering wheel and check the air bag and wiring?
  30. #29
    Feb 2012
    124
    i'm gona get it back on the diagnostics in the next few days and write down all the faults that i can find with the airbag and esp and then write it down on here. see if anyone can work it out
  31. #30
    Fossie
    Rhubarb Triangle
    3,969
    you've got me worried now! lol ...how do a dismentle the steering wheel and check the airbag and
    wiring?
    With the wheel in the straight ahead position turn it 90 degrees left (or right) and look at the lower steering column cover and you should see a plastic cover plate which you remove with a small screwdriver. It may not be there in your case but in the hole is a Torx head screw which you have to remove.
    Then turn the wheel to 90 degrees the other way and do the same thing with the other screw.
    The airbag will gently lift away from the wheel with the wiring loom still attached. If you see all this in place then you can remove the plug from the airbag but disconnect the battery first.
  32. #31
    Feb 2012
    124
    okay cheers, i'll do that on my next day off work
  33. #32
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    I have DONE this without an issue and a few AUDIZINE members have done the same thing for their A4s..
    Single stage to double stage airbag.. Just dig on internet.. There are some cables has to be rewired.. within the airbag plugs..
    Dont lose your faith man! its possibe UNLESS you do not want to mess with ur airbag & sensors' wires..
    '' Wanna Trade Your Pre-facelift BRUSHED ALU interior trim with my Piano Black ones? '' PM me..
  34. #33
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by kemiksiz View Post
    You may well have done it mate but how do you know it will work if it needs to ?
  35. #34
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    One of the guys had an accident, so we had the proof :D But who knows.. Also there was not any error lights on..
  36. #35
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    My penny's worth..
    They give 04 wheels away on the bay. Great shame because i just took one up the tip from my 04, 3.2 having advertised it for £20 with an airbag and got no response.
    The 04 wheel is a better looking bit of kit as well. this was mine
    Do not mess with the wheel or airbag or wiring full stop. Get the right wheel and airbag so you know for certain the bag will work. I fitted a 08 flat bottom wheel to my 04 and it never had an airbag light come on so that tells you nothing. If you want a working airbag for sure get the right parts.
  37. #36
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    This is what you want, check with the guy the year but i'm sure that will fit and work
    Audi A3 steering wheel and airbag | eBay
  38. #37
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    Being a 2004 you'll more than likely have the Steering ECU 1K0-953-549 or 1K0-959-549-A, both of which are only compatable with the Single Stage Airbag. If you have one of these ECU's then you'll also have a Type 1 Slipring.
    If you do actually have an airbag then check your Steering ECU and Slipring part #'s. You'll need a different Steering ECU and compatable Type 2 Slipring to work with a Dual Stage airbag.
    I'm still inclined to agree with Paddy however, by only installing what was initally designed to be on the car -- if you're bothered about the airbag deploying that is. There was a thread somewhere of a guy who did this mod on his 2004 using the compatable 'F' ECU and Type 2 'D' slipring, to find when he ploughed into a tree, his airbags didn't fire. You can get the facelift wheel onto a pre-facelift no problem and without any errors showing but the airbag actually deploying seems to be a bit hit & miss.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  39. #38
    Feb 2012
    124
    Okay guys thanks for the info, I really wana keep the wheel so might look into steering ecu and new slip ring and try and find some prices off breakers, and I'm gona go the garage tomorrow and get the car put back on the diagnostics, I'll write down all the esp and airbag faults and hopefully have them all on here by the evening
  40. #39
    Fossie
    Rhubarb Triangle
    3,969
    Steering ecu and slip ring will not sort the airbag out. Did you check to see if you actually have an airbag ?
  41. #40
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Harris
    I didnt say buy the proper bits for nothing. You cant make that set up work on your car....its that simple.
  1. Audi A3 S-line steering wheel
    By jasonallen in forum For Sale/Wanted - Audi Parts
    Last Post: 27th October 2011, 11:54
  2. Replies: 9
    Last Post: 30th March 2011, 00:33
  3. Upgrading steering wheel to s-line wheel... Airbag question...
    By Martin69 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2010, 13:12
  4. From 8P1 S-Line DSG Steering Wheel to 8P2 MF Steering Wheel
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2010, 19:27
