JMB RetrofitsVolks Autos
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 103
  1. #41
    Feb 2012
    124
    Quote Originally Posted by paddy View Post
    Harris
    I didnt say buy the proper bits for nothing. You cant make that set up work on your car....its that simple.
    sorry just confused because people are saying you cant fit it and some people are saying you can but its 50/50 chance if the airbag will deploy or not.
  3. #42
    Feb 2012
    124
    okay so got a little update, been the garage today and got my car on the computer, i'll start with the airbag faults
    Air bag faults -
    024c - Driverside front airbag ignitor circuit 1 maximum exceeded
    0634 - ignition circuit headbag driverside, maximum exceeded
    028E - belt tensioner ignition circuit driverside, front less then minimum
    04C2 - ignition circuit side airbag passenger side front maximum exceeded
  4. #43
    Feb 2012
    124
    esp faults -
    030A - Steering wheel angle sensor mechanical fault
    032A - Front axle pressure sensor basic setting not performed/ wrong
    030A - Steering wheel angle sensor basic setting not performed/wrong
    058F - lateral acceleration sensor basic setting not performed / wrong
  5. #44
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,607
    This is the bottom line.
    With the correct ECU and Slipring you can fit it fine and there will be no fault codes but there is a chance that your airbag may not deploy if you're ever in an accident.
    If you're not bothered about the airbag deploying (which you should be) then by all means buy an ECU and Slipring and keep the wheel and it'll pass MOT's no problem but our recommendation, for obvious reasons, is to go back to your original wheel in order to know that the single stage airbag will deploy on impact.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  6. #45
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Definitely need to change the ECU/Slipring or Revert back to the original wheel.
    The fact that Drivers Ignitor 1 is only mentioned and not Ignitor 2 means that the ECU/Slipring is only looking for 1 Ignitor (Single stage airbag)
    Like I said in my previous post, I'd recommend changing back to the original Single-stage airbag which will fix all of your problems and you'll probably end up in profit as you'll be able to sell the wheel and airbag you have now for ~£250 and pick up a Single Stage wheel and airbag for ~£50
  7. #46
    Feb 2012
    124
    okay then i think i'll just buy the original wheel, i'll put a bid in on the link paddy put up
    Audi A3 steering wheel and airbag | eBay
  8. #47
    27,029
    Listen to what you are being advised please, running out & buying another wheel with proper airbag will help 1 thing, but wont resolve everything, you need to clear or fix the other warnings present, namely the angle sensor etc that need calibrating, once these have cleared then attack the airbag issues, they're 2 different systems, not 1 problem, but 2.
  9. #48
    Feb 2012
    124
    so far i need to get the original wheel, o/s curtain airbag, o/s seat belt with tensioner.
    does anyone know what i will need to get to cure this?
    and the steering wheel angle sensor fault wil that dissapper when the new steering wheel is fitted?
    isnt basic setting something to do with cailbrating, when you turn the wheel to the left, turn to the right, drive forward etc..?
  10. #49
    Feb 2012
    124
    okay i'm listening, so i need to attack these ones first -
    done a bit of research on the internet and found this -
    VW Golf (1K) Brake Electronics (MK60) - Ross-Tech Wiki
    it looks like its got the information to cailbrate all 3 of these (let me know if i'm wrong)
    will it have to be done on a vagcom because my friend has a bosch diagnostics system?
    030A - Steering wheel angle sensor mechanical fault - will this result in me having to get a new steering wheel angle sensor and should i get this before i do cailbration?
    sorry about all the questions i just dont know much about this
  11. #50
    27,029
    Yes try & calibrate the angle sensor etc 1st, if that still shows issue with sensor then you'd need to strip down the steering column to check the pins/connections as if someone's been messing with that area, they may have fitted it back badly & yes use VCDS, not the bosch rubbish.
  12. #51
    Feb 2012
    124
    so i need to find someone with a vag com to get the sensors calibrated, i have put a thread up to try and find someone near me, amar06fbr has kindly offered to help me but he does seem pretty far away in bradford, i dont suppose theirs anyone on this thread who lives a little bit closer to the west midlands with a vag com and could kindly help? if worst comes to worse i will just drive 100 miles to bradford.
  13. #52
    Fossie
    Rhubarb Triangle
    3,969
    There's a section of the forum called 'VCDS users'. That will list people in your area who will help.
  14. #53
    Feb 2012
    124
    i've found someone thats in cheshire and is willing to help, so fingers crossed might be able to get these sensors calibrated pretty soon.
  15. #54
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    im gona be at tamworth saturday around 7pm
  16. #55
    Feb 2012
    124
    bez tamworth is pretty close and i'm free saturday night aswell, so might have to take you up on that offer, pm me your number
  17. #56
    Feb 2012
    124
    Just got back from meeting bez in tamworth, gotta say what a real nice helpful guy! we've managed to calibrate evrythin and now the esp light is off but now my steering has gone really heavy, like my powersteering pump has stopped, it was pretty dangerous on the drive back, next step I think is to get the new steering wheel.
  18. #57
    27,029
    Thats part of the calibration, when you do these, sometimes you have to do the steering angle sensor again as it can reset it & steering becomes hard, but in most cases a drive down the road should clear this, if not then needs another vcds calibration doing.
  19. #58
    bez101's Avatar
    Jul 2008
    8,430
    i did the angle sensor 2 times it just would not let me do the Steering Limit Stop Adaptation i tried 5 6 times just wouldnt have it<br><br>codes below&nbsp; im back down his way weekend last night i was really busy had a daft meal had to sort so couldnt have any longer on it <br>i had to do my a3 angle sensor then the steering limit stop a few days ago and that did it 1st try i dont think the steeringwheel bag has had the wireing modded
  20. #59
    bez101's Avatar
    Jul 2008
    8,430
    VCDS codes for the a3
    5,February,2012,19:24:25:27402
    VCDS Version: Release 11.11.2 (x64)
    Data version: 20120126
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
    VIN: WAUZZZ8P44A028058 Mileage: 112680km/70016miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5334
    Revision: 12345678 Serial number: AUX7Z0C5FN60KR
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 2756117796F635B
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0055942
    VCID: 336EF527522E49B
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    01423 - Lateral Acceleration Sensor (G200)
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 A HW: 8P0 820 043 A
    Component: KlimavollautomatH11 0120
    Shop #: WSC 00000 000 00000
    VCID: 2A50E84385E4083
    6 Faults Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 214
    Mileage: 107532 km
    Time Indication: 0
    Date: 2010.10.14
    Time: 00:00:53
    Freeze Frame:
    Temperature: 19.0°C
    Voltage: 11.90 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 111965 km
    Time Indication: 0
    Date: 2012.01.05
    Time: 19:59:58
    Freeze Frame:
    Voltage: 7.90 V
    01592 - Air Quality Sensor (G238)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 3
    Fault Frequency: 118
    Reset counter: 162
    Mileage: 100850 km
    Time Indication: 0
    Date: 2010.01.15
    Time: 10:21:46
    Freeze Frame:
    Temperature: 15.0°C
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 112078 km
    Time Indication: 0
    Date: 2012.01.02
    Time: 00:01:18
    Freeze Frame:
    Temperature: 4.5°C
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 55
    Reset counter: 123
    Mileage: 109613 km
    Time Indication: 0
    Date: 2011.12.17
    Time: 13:31:21
    Freeze Frame:
    Temperature: 8.5°C
    01856 - Temperature Sensor for Heated Seat; Right Front (G345)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 112078 km
    Time Indication: 0
    Date: 2012.01.02
    Time: 00:01:18
    Freeze Frame:
    Temperature: 4.5°C
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H27 0401
    Revision: 00000000 Serial number: 00000006584392
    Coding: 018ACF00A2141000000000000000000000
    VCID: 3B7EDD077A7E81B
    Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
    Component: Wischer WWS Audi350 0180
    Coding: 14352400
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    VCID: 458ABBFF0CBAC7B
    4 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    01588 - Igniter for Head-Airbag; Drivers Side (N251)
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    002 - Lower Limit Exceeded - MIL ON
    01218 - Side Airbag Igniter; Passenger Side (N200)
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 007 0030
    Coding: 0000012
    VCID: 3064FA2BA338723
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 D HW: 8P0 920 980 D
    Component: KOMBIINSTR. VDO H25 0070
    Revision: D04 Serial number: 2245CD04000850
    Coding: 0004403
    Shop #: WSC 00415 210 57172
    VCID: 3874C20B4B48AA3
    1 Fault Found:
    01298 - Instrument Cluster Lamp Test
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 138
    Mileage: 111232 km
    Time Indication: 0
    Date: 2012.01.02
    Time: 00:01:23
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0070
    Revision: 08 Serial number: 17001035275030
    Coding: 3D0F0B40070101
    VCID: 26481C7391FC2C3
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D04 Serial number: AUX7Z0C5FN60KR
    Shop #: WSC 00415 210 81338
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H09 0010
    Coding: 0000048
    VCID: 3972C70F7042B3B
    1 Fault Found:
    01340 - Mirror Adjustment Switch
    008 - Implausible Signal
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 143 K
    Component: EPS_ZFLS Kl.7 0308
    VCID: 3260F023AD34403
    1 Fault Found:
    02546 - Steering Limit Stop
    Freeze Frame:
    Mileage: 2680 km
    Temperature: 36.0°C
    Voltage: 14.00 V
    Voltage: 13.90 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0030
    Coding: 008800186D288505485AC63000
    Shop #: WSC 00046 046 52295
    VCID: F9F2870FB0C2F3B
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H01 0010
    2 Faults Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication - Intermittent
    000 - -
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Coding: 0000048
    VCID: 3A70D8037544B83
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H51 0060
    Revision: 05S Serial number: AUZ2Z3C1057706
    Coding: 0001001
    VCID: EFE6B957FE86ADB
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 242
    Mileage: 137450 km
    Time Indication: 0
    Date: 2009.10.01
    Time: 00:15:58
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 151
    Freeze Frame:
    Bin. Bits: 10
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 151
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 137452 km
    Time Indication: 0
    Date: 2009.10.01
    Time: 01:14:27
    Freeze Frame:
    Bin. Bits: 10
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 19
    Reset counter: 139
    Mileage: 108836 km
    Time Indication: 0
    Date: 2010.12.10
    Time: 18:55:09
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
    Component: PTC-Element 0303
    Revision: 00400000 Serial number:
    VCID: 2952174F80E203B
  21. #60
    Feb 2012
    124
    I've also got a problem with my central locking, everytime I lock the car, the alarm goes off and the only way I can stoip the alarm is by opening and closing the passenger door and then it will lock. Does any of these fault codes look like the suspect?
  22. #61
    27,029
    Are those codes after your calibrations Bez?
    If after then tbh mate there's a fair few faults there, needs properly looking at & checking through 1 by 1.
  23. #62
    bez101's Avatar
    Jul 2008
    8,430
    NHN yes after
    theres quite a few to get through
    as i said i just didnt have more time its had a side crash if i rember right clocks plastic is cracked so i thing they have replaced the dash or it was hit hard but iv told him get a wheel and ill refit and have a good look through the codes
  24. #63
    27,029
    Yeah tbh its only thing you can do, go through 1 by 1.
  25. #64
    bez101's Avatar
    Jul 2008
    8,430
    its gona cost
  26. #65
    27,029
    Yeap exactly, that list of faults, wont be a quick fix.
  27. #66
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    I worked on a fellow forum members car with the 00778 Steering Angle sensor fault and Stop Limit fault.
    Tried to calibrate but wouldnt calibrate properly so went about replacing the Slip Ring and calibrated and worked fine. Could be the same here?
    Regardless of the steering wheel being the wrong one the Steering Angle sensor fault shouldnt be there.
    Like said above, not gonna be an easy task.. I'd love to get my hands on it haha.
  28. #67
    bez101's Avatar
    Jul 2008
    8,430
    i also think its the slip ring
    after the crash it was fully bodged
  29. #68
    bez101's Avatar
    Jul 2008
    8,430
    Quote Originally Posted by jb0o View Post
    oh while your here how much for cruise cowl and dis stalk posted ?
  30. #69
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Off the top of my head I could get them to you for £90 delivered.
  31. #70
    bez101's Avatar
    Jul 2008
    8,430
    that will do me
    bank transfer ?
  32. #71
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    I'll shoot you a PM now mate.
  33. #72
    27,029
    You & me both, its a challenge car lol
    Yeap as I mentioned further up, wheel & steering angle are independent, so need to deal with seperately, but after what Bez has said, god knows what they've done to the car, just hope it was dirt cheap.
  34. #73
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,607
    Haha, Id expect it to be cheap.. Was certainly a cheap repair.. If you can even count it as a repair!
  35. #74
    Feb 2012
    124
    I'm still on the look for a new steering wheel, the only one I can find is this and it seems a little expensive - http://item.mobileweb.ebay.co.uk/vie...d=88982225728A few days after bez did the calibration the heavy steering knocked off and the car drove fine but yesterday randomly the esp light came back on and it doesn't look like its gonna be knocking off any time soon.
  36. #75
    27,029
    You need someone to spend time on the car to look at fixing the issues, no other way.
  37. #76
    Feb 2012
    124
    been today to collect a few bits for the car, 2004 3 spoke audi steering wheel, including air bag and all of the steering column, air bag module, passenger and drivers seat belt tensioners, drivers and passengers curtain roof airbags (only drivers is needed) and a dash board that i didnt need but the guy gave me.
    hopefully after getting these fitted and a little help off bez and his vagcom, we can clear a few of the faults
  38. #77
    bez101's Avatar
    Jul 2008
    8,430
    Quote Originally Posted by harris9053 View Post
    i dont mind codeing them up ill even go as far as fitting the wheel slipring etc
    but you will have to sort the roof bags module and seatbelt bits
    i just wont have time to fit the rest
    ill be passing tamworth as every week but i aint got hours as i head to south wales to see my missus and kid on the weekends
  39. #78
    Feb 2012
    124
    no problem bez, i'll get everything fitted first apart from the steering wheel and column, thanks for your help
  40. #79
    bez101's Avatar
    Jul 2008
    8,430
    you want the column fitting ?
  41. #80
    Feb 2012
    124
    no just the wheel and slip ring, i just said that because the column is connected to the wheel at the moment
  1. Audi A3 S-line steering wheel
    By jasonallen in forum For Sale/Wanted - Audi Parts
    Last Post: 27th October 2011, 11:54
  2. Replies: 9
    Last Post: 30th March 2011, 00:33
  3. Upgrading steering wheel to s-line wheel... Airbag question...
    By Martin69 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2010, 13:12
  4. From 8P1 S-Line DSG Steering Wheel to 8P2 MF Steering Wheel
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2010, 19:27
