AH FabricationsVolks Autos
    Nov 2006
    51
    Help - Another Dual mass flywheel on its way out
    Hello, so yes, on my 2007 A3 sportback 2.0 140cv BKD, first DMF replaced under warranty at 69.000km, and now at 131.000 the symptoms of it being about to die start to show again.
    When I turn the ignition of, the engine shudders with a clonking rattle hard metalic sound just after it stops, the sound comes from the lower part of the engine bay.
    Is it safe to say that the DMF is about to die again (same symptoms as last time), or could it be the shut off valve acting up?
    If it was the DMF, can anyone recommend LUK or SACHS? I seem to remember that LUK had an issue with their DMF's.
    Thanks.
    Dec 2011
    York
    93
    DMF failure;
    On idle does your engine make a distinct rattling noise that is distinguished upon clutch depress ?
    Also
    Upon drive, does your gearstick vibrate.
    If neither then not DMF.
    Nov 2006
    51
    Quote Originally Posted by - Jrd - View Post
    DMF failure;
    Also
    On idle, no rattles no vibrations...smooth running.
    Upon drive, no gearstick vibrations.
    So if it is not the DMF, what else could it be?
  1. Dual Mass Flywheel
    By sidibear in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th October 2011, 00:40
  2. Dual mass flywheel
    By cee-gee in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th May 2011, 19:03
  3. Dual Mass Flywheel
    By RJB1875 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2010, 21:24
  4. Dual Mass Flywheel
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 15:38
  5. A4 Flywheel...dual mass?
    By robw963 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2004, 22:24
