Badger5AH Fabrications
    Apr 2011
    Durham
    38
    A3 SE suspension swap
    Hi I was wondering if sombody could help me with this one.. I want to change the suspension from my a3 2.0 tdi SE to the sline suspension (one I finally get my hands on a complete set) I was just wondering wether it was just a straight swap or wether there is alot more involved. Thanks Paul
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by MornyA3 View Post
    As long as its from the same model/engine/number of doors as yours then it will be a straight springs and shocks swap.
    However, if I were you I wouldn't go down that route. If that is the sort of drop you are looking for (25-30mm) then you'd be better off going for a springs/shock kit such as the h&r cup kit, bilstein b12 kit, or eibach pro kit matched with koni fsd shocks.
    It'll cost you more but will offer a much better ride and will look slightly lower than s-line.
    Apr 2011
    Durham
    38
    Hi ads, alright so how much are them kits? Yeah that's the sort of drop I'm looking for I just don't want to feel as if my spine is gonna go through my skull every time I hit a bump ha
    plezz's Avatar
    Aug 2011
    Romford
    233
    Ask Damian at DPM for a quote, very helpful chap! should be able to supply them for you, and i believe he does a price match in case you find them cheaper elsewhere.
    EDIT - i forgot to add, i'm also looking into doing something similar - dropping my SE down by 30mm. i'm looking at eibach pro kit, and where my shocks are in ok condition i should be able to get away with just changing my springs - won't be quite as comfy as changing shocks as well but should be at least a little comfier than S Line stock AFAIK.
    Plezz.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    You're looking at about £500-£600 for a spring/shocks set, but then you've got to add fitting/alignment which could add another couple of hundred.
    If you go for springs only then you could do it all for about £300-£350 (the springs will cost about £150ish).
    Jan 2011
    27
    Quote Originally Posted by Ads View Post
    Has anyone fitted the Eibach Pro-Kit to an SE Sportback and kept the original SE shocks (and run it for a descent mileage)?
    If so, 2 questions:
    1. How did the Pro-Kit ride compared to the original SE set-up?
    2. Were there any problems with the shocks having run them with the Pro-kit springs for 20-30k miles?
    Any other thoughts feedback on the set-up?
    Thanks!
  1. A3 8P halogen headlamps swap to single xenon only is it really swap + plug and play?
    By thebedscompany in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2012, 17:48
  2. Suspension swap
    By chris1988brown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2011, 23:06
  3. Engine swap Q - APY - APX swap
    By ci-ryder in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2011, 11:43
  4. Replies: 25
    Last Post: 17th February 2011, 13:45
  5. Clunk from front suspension, not suspension arms though?........
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2008, 21:37
