JMB RetrofitsAH Fabrications
Results 1 to 12 of 12
    Sep 2011
    86
    Help needed with my Key. Won't start the car just says SAFE?
    Hi Guys
    I bought a new key fob off ebay and just took all the electronic bits, key and transponder out the old key and put it in the new case. It will unlock the door with the remote but when I try start the car it just come up saying "safe"
    Anyone got any idea's?
    Richard
    Jan 2011
    northants
    165
    immobilizer issue
    did you damage the chip?
    Sep 2011
    86
    Dont think so!
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Quote Originally Posted by Hendo View Post
    Dont think so!
    Hold your old key by dash/ignition if it works you need to take the key apart find the chip and put it in the new one!
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    Fossie
    Rhubarb Triangle
    3,969
    Are you sure you transferred the immobiliser chip across? It's a capsule shaped glass object that is held in the plastic and nothing to do with the circuit board.
    The one in the new key fob will not work with your car.
    Sep 2011
    86
    Quote Originally Posted by S3 Dave View Post
    Din't work!!
    Sep 2011
    86
    Yeah I transfered the chip across?
    Fossie
    Rhubarb Triangle
    3,969
    Not good ! You couldn't have got the chips mixed up could you ? Clutching at straws I know but if the chip has been damaged it's a trip to Audi (somehow!) and a new key coded.
    Sep 2011
    86
    Got it sussed I stripped the key down and found it already had a immobiliser chip hidden inside. I removed that chip and replaced it with my original on and worked no problem.
    So turns out that it will not work with 2 immobiliser chips inside the key housing lol.
    Fossie
    Rhubarb Triangle
    3,969
    Obviously not ! That's why I said transfer the old chip to the new fob (see post #5). There is only room for one chip in the fob so how and why you put two chips in is a bit of a mystery I have to say !!
    Sep 2011
    86
    Well I was presented with a plastic area where the old chip was hidden underneath. I couldn't get it out originally so I assumed it wasn't meant to be move to I just secured in place my old chip and hoped for the best!
    I should have maybe asked for advice first rather than just go at it. Oh well live and learn.
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    172
    Thank you for this thread :D I also bought fob off ebay and moved everything except immobilizer chip! :D And boy was I scared when engine shut down, and yellow heater sign started to flash with SAFE :-/
    Google saved me
  1. Help needed: Changed spark plugs now car won't start
    By MG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2011, 13:11
  2. Car won't unlock using unlock button on key / key won't start car!!
    By evapor8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2010, 09:42
  3. Help needed Urgently - car won't start
    By Brooksy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2010, 18:06
  4. Replies: 13
    Last Post: 14th February 2010, 16:48
  5. Can only start car with master key - immobiliser problem
    By voteforpedro in forum General Technical / How To
    Last Post: 13th August 2008, 17:16
