Volks AutosChris Nott
    APU
    APU's Avatar
    Apr 2009
    Scotland UK
    13
    Engine Experts, please help needed
    Hey peeps
    My good old BKD (2005) failed last month ...... with only 90k on the clock
    One exhaust valve has broken off and fallen into the block, the broken part was stuck in the piston and didnt bounce a lot so no damage to the walls and little damage to the head, phew :D
    Several weeks later I have a skimmed head with new valves and one new piston.
    When i bought this car last year it was noisy like a lazy/failed tappet or two and wondering now should i replace the followers as well? They are not cheap and at £25 a pop will be additional 400 pounds which i dont have
    I've made two short vids and asking our experts to advise me if this play is acceptable? I have 4 followers with such play, the rest are rock hard.....
    BKD inlet follower play - YouTube
    BKD followers/rocker arm play - YouTube
    In advance, thanks for your help
    Regards
    APU
    APU's Avatar
    Apr 2009
    Scotland UK
    13
    This is what i was looking for
    regards
    Aug 2010
    1,540
    if money is tight id just replace the ones that are displaying the knackard tappets.
    has the engine not been run yet since the rebuild?? after its run up to temp. you might find the tappets will refill with oil and be fine.
    APU
    APU's Avatar
    Apr 2009
    Scotland UK
    13
    Hi Murran,
    I think you are correct and once the engine is running it will be better but taking into account that it was noisy in the first place before the rebuild i think it will still be noisy unless i replace the broken rockers. After reading Elsa i decided to change 6 faulty arm.
  1. a6 2.7t.... help needed (s4 engine)
    By audi-a6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2012, 22:13
  2. Pc experts advice needed
    By 205man in forum General Chat
    Last Post: 29th August 2010, 22:14
  3. Estimate for repairs - Opinions needed also (8P experts needed)
    By nyzrox in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2008, 22:02
  4. Replies: 8
    Last Post: 21st November 2007, 02:40
  5. Help needed - Vag-com owners/experts?
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 18:15
