indicator problem
reece-page
NULL
afternoon guys
I had the warning light saying light hand turning light, so i look in the manual and change the bulb and the fuse and its still not working so wondering if you guys had any ideas
cheers
Reece
Reece, it could be some corrosion in the bulb holder, or even a disconnected wire feeding the indicator unit. Also check that the bulb you have used as a replacement is the right type, and also check to see if it is functional. Use a 12v battery to see if the new bulb lights up. Good luck.
afternoon guys
cheers
Reece
Did you check to see which bulb - front, rear or side ? If any of those are faulty you will get a warning light.
725
543
6
8K
548
698
T8DPR
T
