Sky InsuranceAH Fabrications
Thread: drivers seat
    Jan 2012
    powys
    59
    Question drivers seat
    hi guys
    on my drivers seat , if i let people in the back on my sportback the seat will slide forward and tilt forward ,but when i put it back down the seat is in a different place, so i have to adjust the seat again.
    also when i adjust the seat down on the lever it will go so low then it drops then i need to lift it up again on the handle .
    i used to have a mk4 golf it was the same seat mecanisam but no issues.
    Helifella's Avatar
    Flying low level
    Nov 2011
    Knaresborough
    361
    Follow Helifella On Twitter
    The seat shouldn't slide or tilt on a sportback as it's a 5 door. But if you meant you have a three door then perhaps slide the seat to where you want it then and only then flick the back up to lock it in your desired position.
    I don't understand your point with the lever adjustment - do you need to drop it so low?
    RegardsHeliFellaVCDS newbie.8V now ordered...I.A.M. Member http://www.iam.org.uk/about-us/ '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates, gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Sportback huh? Can they not just use the rear doors?
    On my 3-dr it's annoying that it doesn't have a memory for when you click it back, but at the same time it means you don't squash people until you can slide it forward when they get in behind a seat that's too far back.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Mji
    Mji's Avatar
    Oct 2011
    12
    Weird. My s3 3 door manual drivers seat has a memory of sorts. Pull the release catch tilt forward to steering wheel till it clicks slide about as much as you like. When ready slide as far back as it goes and it stops where it was initially then once in position release the tilt catch and the back goes back to the original spot. No readjustments needed.
    Present -
    2009 Audi S3 TFSI Quattro
    past -
    2006 Mercedes SLK350
    2004 Honda S2000
    1995 Toyota MR2 (Mk2)
    1996 Fiat Punto 55SX
    1993 Rover Metro
    1991 Rover Metro (RIP vs tree)
  1. Removing the drivers Seat
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2010, 16:11
  2. Drivers seat won't go as low as passenger seat
    By spitfiredealer in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2010, 16:01
  3. Drivers seat
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 12:58
  4. Two problems with drivers seat [S3 8L]
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2009, 13:39
  5. drivers seat
    By banny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th April 2007, 20:16
