KowalskiW8 Performance
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By AidenUK
Thread: audi a3 problem after car accident
    Feb 2012
    Post Thanks / Like
    Unhappy audi a3 problem after car accident
    hello
    i have a light damaged Audi A3 2004 (BGU engine).. Car has light damaged front of it..The vehicle locked itself after car accident,
    Airbags aren't open but seat belts locked and don't move. also, after start engine, the vehicle is stopping within 2 or 3 seconds and stopping to fire(ignite).
    besides, it saying "Safe" on the vehicle's monitor. What i should do to fix this circumstance?
    note: the vehicle gave "P1570" error. Ross-Tech: VAG-COM: Immobilizer 2 ECU Swapping i followed and performed steps where is on that site but it gave "vag-com licence" error..
    s3dave's Avatar
    mediator
    west yorks
    6,981
    Post Thanks / Like
    I think you will have an 8p chassis so this is the wrong section...
    Quote Originally Posted by 16Klappe View Post
    And anyway, less of the thinking because I'm ALWAYS right!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,607
    Post Thanks / Like
    Moved
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Are you using a genuine VCDS cable?
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    Feb 2012
    Post Thanks / Like
    i'm sorry about wrong section.. yes i borrowed to cabe from one of my friends.. 704.1 cable version. i'm not sure about cable's genuiue.
    Feb 2012
    Post Thanks / Like
    i will just buy 10.6.0 cable version, after this it will help me about it? i mean it can be fix?
    May 2009
    West Yorkshire
    1,290
    Post Thanks / Like
    Quote Originally Posted by controller View Post
    You need a genuine version of VCDS as the pirate ones don't work correctly.
    It can be fix and then you will be excite.
    JamesO likes this.
    Audi A3 S-Line 2.0L TDI 140 Sportback (56)
    Mar 2011
    Cleveland
    228
    Post Thanks / Like
    You will need new seatbelts.
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    sounds like the belt pretensioners have gone off.
    wierd that it seems like an imobilizer fault. think you'll need some dealer help to recode it via their online to germany jobbie.
    Khufu's Avatar
    West coast of Scotland
    5,691
    Post Thanks / Like
    yup, there is definately a fault with immobilizer hence the words SAFE. A scan with a proper VCDS lead will let you know which part is causing the fault.
    Feb 2012
    Post Thanks / Like
    i appreciated for all answers..
    vcds's scan log in the below:
    Code:
    Friday,10,February,2012,13:00:50:36838
    VCDS Version: Release 10.6.2
    Data version: 20101123
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8P44A07****
    Address 01: Engine        Labels: 06A-906-033-BGU.lbl
       Part No: 06A 906 033 BC
       Component: SIMOS71 1.6l 2VG    5483
       Revision: 00000003    Serial number: AUX7Z0C8F*****
       Coding: 0000075
       Shop #: WSC 06435 000 00000
       VCID: 61C2B900871*****
    9 Faults Found:
    18080 - Coolant Fan Control 1: Open or Short to Ground
                P1672 -- 009 -- Open or Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Temperature: 7.5°C
                        Temperature: 7.5°C
                        Speed: 0.0 km/h
                        RPM: 0 /min
                        Temperature: 7.5°C
                        Temperature: 7.5°C
                        Speed: 0.0 km/h
    17979 - Left Engine Mount Solenoid Valve (N144): Short to Plus
                P1571 -- 008 -- Implausible Signal
                 Freeze Frame:
                        RPM: 0 /min
                        Temperature: 7.5°C
                        Voltage: 11.53 V
                        Bin. Bits: 00000001
                        RPM: 0 /min
                        Temperature: 7.5°C
                        Voltage: 12.04 V
                        Bin. Bits: 00000001
    18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
                P1639 -- 009 -- Open or Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Temperature: 7.5°C
                        Load: 8.6 %
    16788 - EGR System: Range / Performance
                P0404 -- 008 -- Implausible Signal - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Voltage: 11.12 V
                        Load: 0.0 %
                        Load: 0.0 %
                        RPM: 0 /min
                        Voltage: 0.00 V
                        Load: 0.0 %
                        Load: 0.0 %
    17966 - Throttle Actuator (G186): Electrical Malfunction
                P1558 -- 006 -- Short to Plus - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Bin. Bits: 00000001
                        Load: 100.0 %
                        Load: 0.0 %
                        RPM: 0 /min
                        Bin. Bits: 00000001
                        Load: 100.0 %
                        Load: 0.0 %
    17585 - Bank2: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
                P1177 -- 007 -- Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Bin. Bits: 00000001
                        Load: 100.0 %
                        Load: 0.0 %
                        RPM: 0 /min
                        Bin. Bits: 00000001
                        Load: 100.0 %
                        Load: 0.0 %
    17578 - Mass Air Flow Sensor 2 (G246): Supply Voltage
                P1170 -- 007 -- Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Mass Air / Rev.: 0.0 mg/str
                        Absolute Pres.: 1005.5 mbar
                        Lambda: -1.0 %
                        RPM: 0 /min
                        Absolute Pres.: 1026.8 mbar
                        Lambda: 1.0 %
    16506 - Throttle Position Sensor (G69): Signal too Low
                P0122 -- 009 -- Open or Short to Ground - MIL ON
                 Freeze Frame:
                        Temperature: 4.5°C
                        Temperature: -40.5°C
                        Temperature: 4.5°C
                        RPM: 0 /min
                P1639 -- 007 -- Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 0 /min
                        Voltage: 11.73 V
                        Load: 14.5 %
                        Load: 0.0 %
    Readiness: 1110 1101
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No: 09G 927 750 B
       Component: AQ 250 6F           0436
       Coding: 0000008
       VCID: 30640C449C7*****
    3 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
                004 -- No Signal/Communication - Intermittent - MIL ON
    01315 - Transmission Control Module
                013 -- Check DTC Memory - Intermittent - MIL ON
    01693 - Valve for Throttle (N211)
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 D
       Component: ESP FRONT MK60      0102
       Coding: 0051846
       VCID: 336E03486D6*****
    10 Faults Found:
    00810 - Sensor 1/2 for Brake Pressure
                005 -- No or Incorrect Basic Setting / Adaptation - Intermittent
    00779 - Outside Air Temp Sensor (G17)
    01436 - Brake Fluid Level too Low
    01048 - Diesel Electronic Warning Light (K104)
    00488 - Right Rear Outside Door Handle Central Locking Button (E372)
    00783 - Positioning Motor; Left Rear (V78)
                014 -- Defective - Intermittent
    01329 - Convenience System Data Bus in Emergency Mode
    01320 - Control Module for Climatronic (J255)
    00674 - Release Brake Pedal
                002 -- Lower Limit Exceeded - Intermittent
    00286 - ABS Inlet/Outlet Valve; Rear Left (N139)
                012 -- Electrical Fault in Circuit
    Besides, when i enter to immobilizer's section from vcds there is an error "fault codes".. when i enter to there, i saw this one;
    Code:
    Friday,10,February,2012,14:01:30:36838
                    Address 25: Immobilizer       Labels: 1K0-920-xxx-25.lbl
    Control Module Part Number: 8P0 920 930 G    HW: 8P0 920 930 G
      Component and/or Version: KOMBIINSTR. VDO H25 0080
               Software Coding:
                Work Shop Code: WSC 03501 389 *****
                          VCID: 36683A5C7E1*****
    1 Fault Found:
    02241 - Engine Control Module; Immobilizer Data not Adapted
            000 --  -
    and when i followed to this steps from here Ross-Tech: VAG-COM: Immobilizer 2 ECU Swapping, it's saying first part of
    extra field is empty and the second one has "geraet 1030**".. i wonder electric not going to this section or it can be blowing of fuse?
  1. Steering problem since accident - please help!!
    By masterchief in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2011, 12:51
  2. Help and advice guys accident problem :( .........
    By basspower in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 09:21
  3. Whoops... problem with cooling system after accident
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2009, 23:25
  4. Insurance Accident Repair Problem
    By chrisross in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2008, 14:14
  5. car accident
    By POPS11 in forum General Chat
    Last Post: 5th December 2007, 09:51
