Adrian S FluxUnicorn
Results 1 to 13 of 13
    Jan 2012
    Bolton
    13
    Post Thanks / Like
    Revving problem with 2007 s3
    Hi, last couple of months I've noticed that when I come to traffic lights ect and I come to a stop, my car seems to rev on its own to around 1500rpm. Also I found out ... I know it's stupid but when I pump my brake pedal it revs again. :s I cannot think what the problem is. I have a milltek cat back. Itg induction kit , forge spacer valve and I'm running MTM stage 1. Does any one know what the problem is ?
    mjr901's Avatar
    Speed Freak
    Nov 2011
    Worcestershire
    611
    Post Thanks / Like
    Brake pedal shouldn't affect revs I don't think.
    On my 09 S3 I had the forge spacer on and to be honest it really spoilt the car. always seemed to rev funny with it on. I also blame my map but MTM are pretty reputable...so doubt it's that. try taking that spacer off. seemed to work for me and less turbo lag with it off. Doesn't even make that good ' a noise really.
    Other than that make sure air mass sensor is all dandy.
    Mike
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    I had this issue on my last S3 and I could pump the brake pedal and the revs would rise! never worked out what caused it. Sometimes I'd pull up at junction and throttle would surge. Only thing I was wondering was tumble flaps in manifold as I'd had an error code (intermittent), but didn't change it. mAF could also be a culprit, but I never saw DTC.
  5. Thanks Wezcubbages3 thanked for this post
  6. #4
    mjr901's Avatar
    Speed Freak
    Nov 2011
    Worcestershire
    611
    Post Thanks / Like
    How strange :-/ surely the braking system is pretty separate...?
  7. #5
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    Quote Originally Posted by mjr901 View Post
    Does it borrow vacuum from anything or is it total independent?
  8. #6
    mjr901's Avatar
    Speed Freak
    Nov 2011
    Worcestershire
    611
    Post Thanks / Like
    The Germans have probably done something completely nerdy. can't see the need for borrowing a vacuum, master cylinders and slave cylinders, A.B.S pump and all that stuff I thought handled that sort of stuff, I'm definitely know expert though!
  9. #7
    jungleman's Avatar
    Mar 2010
    SW London
    2,039
    Post Thanks / Like
    i had an inconsistent idle on my S3, but that wasn't linked to the brake (cool trick though) mine was cured with a new MAF but the brake link would make me think possibly not the MAF?
    Factory: Phantom Black S3, BOSE, RNS-E, Adaptive Lights, Interior Lights, Auto Lights
    Added: Evolve Stage 2 Map, Evoms CAI, Milltek TBE Non-res With Special Tips Now At 360bhp & 385lb/ft, VWR 4 pots, H&R Springs, H&R Spacers, Sachs Clutch, '09 Rear Clusters, Pressed Metal Plates, TT Air Vents
    To Do list: Now that would be telling
    PM me for Weitec & KW coilovers
  10. #8
    Jan 2012
    Bolton
    13
    Post Thanks / Like
    Another issue that I think is abit strange, when I give the car abit of a rev to around 4 or 5000 rpm. It seems to take forever for the revs to fall back down . Any one else had this problem?
  11. #9
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    Nope, didn't get that.
    Best advice would be to go to a well respected VAG independent like Stattlers and get them to hook it up and run some basic tests.
  12. #10
    mjr901's Avatar
    Speed Freak
    Nov 2011
    Worcestershire
    611
    Post Thanks / Like
    Quote Originally Posted by Wezcubbages3 View Post
    I had exactly that after my remap. it made gear changes horrific. it was a crap map. Viezu. I.e chipped uk. I took it off before I sold it. perfect again
  13. #11
    Dec 2008
    66
    Post Thanks / Like
    So my '57 plate S3 was behaving similarly to yours recently. I had the 1500rpm at traffic light issue, along with the car clinging onto revs after I blipped the throttle.
    Can't say I made the link between brake pedal & revs though - although I can't see why I would've been pumping the brake pedal to be honest!
    Long story short, I replaced the PCV system with a catch can that I picked up off the VAGOC forums, and the car is back to normal. I can only assume that the issues were caused by a vacuum leak.
    I'm sure I've read people talking about testing for this by trying to remove the oil cap from the engine, while it's running. If once you've unscrewed the cap it feels like it's being held down by a vacuum, then you've got a leak..... although it would be great if someone more knowledgeable than me could confirm that!!
  14. #12
    Mar 2011
    Swindon
    98
    Post Thanks / Like
    Try what eslll says, if you leave the car running and try pulling off the oil cap and there is a strong vacumn pulling it back down then it sounds like the problem I had. Go back a page and I started a thread called "revving on idle" it was the breather valve, which was £50 from Audi, then fitted it in less than 10 mins, very simple job, if you can get the engine cover off! Some very helpful info on that thread, sorted my problem out right away.
  15. #13
    DaveyB's Avatar
    No misfires.
    Jul 2010
    UK
    266
    Post Thanks / Like
    Just had this problem myself. Took to my local independant to sort at the same time as a 10k service, which was really only an oil and filter change. They replaced the breather valve, gasket and hoses. System scanned fault codes deleted. My mechanic also mentioned about reflashing the system as it learns and alters ratios from the fault. It also turned out that i had a misfire on all 4 cylinders.
    Total bill came to £357
    Cant wait to take it for a spin, might even get a clean!
    07' S3 8P2 Phantom Black Pearl
    91' Mercedes 300SL R129 Pearl Grey
  16. Likes Hanz liked this post
  1. S3 8P 2007 - Revo Stage 2 Problem
    By lgu00174 in forum Tuning
    Last Post: 23rd August 2011, 18:45
  2. S3/2.0TFSI Weird Revving Problem
    By Staz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2010, 20:27
  3. Electrical problem with A3 1.6 2007, please help
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2010, 20:32
  4. Over-revving problem?
    By PorkyWill in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2007, 01:28
  5. Replies: 4
    Last Post: 2nd June 2006, 20:09
